Question about HP EliteBook 6930p Notebook PC
Blank Screen & no display - HP EliteBook 6930p Notebook PC
    President:
  • 942 Answers
Hi...
Here are some tips
Now let's discuss what we should do when the laptop seems to be booting up without problems, the hard drive spins appropriately, and we even hear the welcome sound of the operating system, but we have no display on the LCD panel.
The easiest and most foolproof method for testing your LCD screen is to hook up the laptop to an external monitor. If the video output on the external monitor looks fine, this means that the problem is with the video connector, with your LCD panel itself, or with the circuitry that turns on the LCD.
What do we do? It all starts with disassembling the notebook. Find the video connector on the system board (if the video is integrated on the motherboard) or on the video card that is attached to the motherboard. Try re-connecting the cables. You may as well locate the display connector on the back of the end LCD panel. Re-seat that one too. This way you can be sure that the problem is not related to connections.
Every now and then the switch located on the system board that turns the backlight of the LCD on and off can become stuck. If this is the problem then your LCD never powers on. There's a little switch that detects whether the screen of your notebook is open or closed. That's the one we're talking about. Try to push it down and hope it gets unstuck.
Disassembling the laptop to unstick this switch is an option, but sometimes you can get away with not taking it apart. Try lightly hitting that plastic switch. But wait, this isn't the only possible cause, unfortunately. Re-seat the other connectors and cables that are present around the LCD panel and the video on board (including the inverter).
All of the aforementioned can usually be fixed, but let's not forget about the screen itself. Sometimes the screen can become defective. Here we'll enumerate a few scenarios where the screen has gone bad and must be replaced: lots of vertical lines or bands appearing on the screen; half of the screen works fine but the other half stays either black (blank) or really white; the output on the screen looks blurred and changes to different patterns; and so forth. These are almost always signs of a defective LCD panel.
However, if the output on the screen is nothing but garbage, such as incorrectly placed special characters, shadows around the characters, unknown randomly placed marks of different colors, distorted or ugly-looking geometric patterns, or tiny little white dots all over the screen, then these are almost always due to the system board or the connection between the LCD panel and the video card. Re-seat the connectors.
All in all, these are some of the most common hardware failures. Nevertheless, before we finish this part, let's name some of the others that will be covered in the second segment of this guide, along with the promised system instability troubleshooting strategies. These include clicking noises coming from the HDD, which is the well-known symptom of a dying HDD. Thus, back up your important data as soon as possible and order a replacement. Overheating is also discussed thoroughly.
Regards
PCmania
Posted on Sep 25, 2009
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | Computers & Internet
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
Sharp Aquos LC-37BX6N - no display. On switching
Off/On The Power switch sudden 4 Straight lines appear on the screen ! what is that & why ?
Oct 05, 2009 | Sharp Televison & Video
Water damage touch screen not working think its getting worse as sometimes does not read game 1st time and screen goes blank sumtimes 2
Friends,
Water damaged screen means total loss, You must have to chage screen. First time while you switch on it water is presented on TFT display, And its damaged to diplay & normaly is blank sometime. Check it in service center of it.,
Thanks.
Sep 23, 2009 | Nintendo DS Lite Console
Blank screen
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 21, 2009 | ViewSonic OptiQuest Monitor
HP EliteBook 6930p Notebook PC Logo
1,098 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
