Question about Philips Televison & Video
Philips 32PFL5322D/37 Black w/any of the analog inputs. Tuner ok
It goes black for a few seconds with analog input from my DVD player on any of the AV inputs. S-video also. Do not have an external Digital source. Tuner works fine with signal from my cable company. When it goes black, I can use a flashlight and I think i see an image, but not sure. Sounds like the inverter, but why only external inputs? Odd.
    Sergeant:
    Champion:
  • 267 Answers
WHEN IT BLACKS OUT, GENTLY PUSH OR TAP ON THE SCREEN. YOU SHOULD SEE A SLIGHT WHITE DISCOLORATION WHERE YOUR PUSHING. IF THIS HAPPENS YOU PROBABLY NEED A MAIN TOTAL ASSY. DO YOU STILL HAVE AUDIO WHEN IT BLACKS OUT?
Posted on Oct 05, 2009
Lg 37lf65 37 inch , screen goes black then returns to normal
Check for loose contacts in power outlet, RC cable, jack and socket. Change input device to some other like a DVD player and see. If problem persists, call in a qualified service technician.
Aug 03, 2012 | Televison & Video
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Philips Televison & Video
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
Crashes after playing a few songs..
Check the battery of player. It may require replacemnt. (ehteshamhusain@gmail.com)
Jul 20, 2009 | Philips GoGear SA5285/37 Digital Media...
Digital tuner stopped working. Analog tuner works fine.
I have the same problem. I checked with Philips and they told me to take it to a local shop. If you get a solution please let me know.
Mar 09, 2009 | Philips DVDR3575H/37
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Can't get analog stations
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Good Luck, big IRISH.
Aug 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Have a 65'' mitsubishi model #WS65411. Screen goes from a good coloered picture to black screen & keeps flashing back&forth between the two.
Ok so you have a projector pointing at a 65'' Screen?
Where is the projector receiving input from ?
Did you hust get this projector ?
please add more details so that we may be of quick and thorough assistance.
Jan 14, 2008 | Televison & Video
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Aug 15, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
