Indesit WIDL126UK that never wants to stop!
Hi, have an Indesit WIDL126UK that will not advance through the selected programme. It will run continuously unless the machine is reset and the next programme selected (i.e. drain, rinse then spin). Drain and spin seem to work ok but there is always water left in the bottom of the drum when you take the washing out. Hope you can help, as I've been waiting for an Indesit engineer for nearly 4 weeks. Best regards Sara.
Did you ever get to the root of the problem >}?
mine is doing the same.
gsxr1000rider73@aol.com
Posted on Jun 26, 2010
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Wixe 127 how do you get max spin 1200 on spin cycle can only get 800 down to off?
It can actually depend on the programme you have selected.
You have to select a programme that will accept a 1200 spin, as not all programmes do.
Hope this helps.
Dec 16, 2009 | Indesit Washing Machines
Select programme machine washes continuously but will not advance to the next programme to rinse.but will move if moved forward manually.
I would suggest that the heater element is not working, this will give the exact symptons you have described.
The element is located at the rear of the washer, you will need a test meter to check it with.
Hope this helps.
Dec 07, 2009 | Indesit W 123 Front Load Washer
My indesit dishwasher won't heat the water. I
HI. this is actually a control issue. your element is ok. replace the control board or timer module asap.
Aug 27, 2009 | Dishwashers
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
INDESIT WIA101 INSTRUCTION MANUAL
Hi - You can download the manual from the link underlined in blue below:
WIA101
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 09, 2008 | Indesit W 123 Front Load Washer
Indesit D61D tripping RCD
the heater is faulty(shorted) and check that the hot water is getting to the appliance as the buzzing is the soliniod being powered but the water is not passing through
Aug 15, 2006 | Maytag 24 in. MDB8600AW Jetclean II...
Washing Machines Logo
282 people viewed this question
Top Washing Machines Experts
