Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Can you repair or replace hdmi input
Phillips 50'' rear projection can not get picture from hdmi cable but can from others
0 characters
1 Points
How do i connect sylvania tablet to a tv
first you need to buy HDMI cable then second connect you HDMI cable from your HDMI tablet port then connect the other end of HDMI cable to your tv HDMI port. from your tv settings you to grab a remote control first then press input button from your remote control and then choose HDMI option then your good to go. hope it will work my friend.
Aug 06, 2011 | TV Accessories
What type of cable do I use to connect the Home Entertainment System. I have an HD tv with a cable supplied HD box. Do I connect the HES to the tv or the cable HD box? Which "wire" do I...
if your HES has a HDMI input and output run 1 HDMI cable from the cable box to the HES then another from the HES to the TV.
If the HES does not have HDMI in then run the HDMI from the cable box to the TV
and an Optical digital audio cable from the cable box to the HES
Dec 03, 2010 | RCA TV Accessories
I have a vb50hrtv device but i don`t have audio
try unplugging and replugging the HDMI cable into a different HDMI socket on your TV, if this doesnt work you may need to set the input to HDMI for your audio on your TV set, (if may be looking at RCA or something for the audio stream), also sometimes its the HDMI cable. try another one if you have another around, this has helped me in the past
Aug 27, 2010 | ViewSonic VB50HRTV TV Input
Gateway laptop to phillips tv
Hi, there, pleasy clarify the following:
What is your Gateway model? Is your TV an older tube type or a new HDTV? Does it have other input ports besides the standard cable input and the RCA you mentioned? You may be able to use S-Video if your laptop has the output port and so does your old TV. Or if you have a newer laptop that includes DVI and you have an HDTV, then you can use a DVI to HDMI cable which by the way will result in the best image quality.
Jun 24, 2009 | TV Accessories
TV will not turn on unless unplugged and wait one hour then plug
Well, sounds like they may be changing the source from T.V. to HDMI or component/composit mode which is bassically for a C player or other connected source like a VHS or Xbox etc.
Allthough if this where the case, you should be able to use the remote to change the source back to the T.V. Antenna or cable if you have it.
WHen it goes blank or seems to be off, does anything you do turn it back on without having to unplugg it first?
If not, it could be bad, you will need to try hooking it up some where else for a while and test it without that person there and see if it the T.V. a bad outlet or the person is actually doing something.
If you think the T.V. is bad or faulty, at this early in its life, I would take it back under warranty before trying to fix it yourself.
Feb 11, 2009 | Philips TV Tuner Video Capture PCI Card -...
Phillips DLP 50 inch has no color great black and white picture
There is no color chip. What it does have is called a motor driven color wheel. The problem is that the color wheel is no longer spinning to produce color. Replace the color wheel and you should be fine.
Dec 31, 2008 | Philips TV Tuner Video Capture PCI Card -...
My rear projection television looks like it is 3D
replace the lamps and then run the synch routine from the main menu. unfortunitly with the expense of the lamps and the low price to replace projection tvs it might not be worthwhile to fix but just replace.
HINT wait till after new years, LCD large screen tv sold about 35% of what was expected during xmas so they will be real real cheap after the 1st of the year
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Connecting computer to tv using usb ports
You cannot,the best thing that you can do is to use the computers video card HDMI output to the HDMI input on TV. The USB is there for things like firmware updates and if your lucky,u may be able to plug in flash drive and view media through it. If your video card has SVIDEO you might be able to use that as well, but HDMI is the way to go if your serious about it, and an HDMI ready video card upgrade for your computer shouldnt cost more than $100,in fact 49 bux at STAPLES right now for a PCIex card.
Dec 20, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV Accessories Logo
144 people viewed this question
Top Philips TV Accessories Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a Philips TV Accessory Expert? Answer questions, earn points and help others
