Question about Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 will not accept any input from keypad - any keypress will get four quick beeps. Power down - no change. Unplug everything - no change. It receives incoming faxes just fine.
  • bob_frei Sep 25, 2009
    The problem was a stuck key on the keypad. I wiggled each key on the control panel and when I wiggled the # key, the problem went away.
    Simple, low tech and effective.
    I like that kind of solution.
    Bob
    Problem Solver:
  • 13 Answers
Maybe one bottom is stock down... puede ser que algun bottom este aplastado u oprimido. verify all bottom in your control panel.
Posted on Oct 05, 2009
I'd like to turn off ECM on my intellifax 2820
There is no option to turn off the ECM on Brother Intellifax 2820 , just set the compatibility to Basic so that the ECM feature will not be available. Just press Menu 201. Press down or up arrow key to select Basic.Press Menu/set and then Stop/exit.
Hope this helps. Rate if it works. Thanks
Apr 13, 2011 | Brother IntelliFax-2820 Laser Fax
Fax machine 2820 not working at all - just beeps no matter what button is pushed
check paper ....!! or ribbon toner is it inserted properly
hope if it helps
Apr 04, 2011 | Brother IntelliFax-2820 Laser Fax
Where can I find an owner's manual to print for a Brother Intellifax 2820?
You can download the required manual from:
http://www.brother-usa.com/manuals/default.aspx?ProductID=FAX2820&ProductGroupID=2
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
Nov 05, 2009 | Brother IntelliFax-2820 Laser Fax
I have a Brother 2820 fax machine and it beeps when I press a button. It still receives faxes but that is it.
When it just beeps on keypress, but other functions not requiring your input (like receiving faxes), the problem most likely is a stuck button. Try pushing each button and wiggle it a little to have it "released". It may not even look pressed down, but one of them most likely is.
Jun 03, 2009 | Brother IntelliFax-2820 Laser Fax
Brother FAX; won't let me do anything - shows date/time/MNL
it sounds like you may have a button stuck in the down position on your control panel. if thats not it, write back. you may have to look closely.
hth,
razors
Apr 02, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Mechine is saying memory full
Do you have paper and toner?
Unplug the power cord for 10 seconds.
Oct 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
200 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
