Question about Watches
How do i set day/date on sekonda automatic 27 jewel gents watch made in ussr ?
SOURCE: Regulating a wristwatch
I would not recommend that you regulate the watch yourself. The risk of damage is too great.I would be happy to regulate it for you. This is a service that I offer my customers free of charge.you pay only the exact shipping costs.
Donald McPherson CW21
www.finewatchmaking.com
Posted on Oct 11, 2007
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Posted on Jun 11, 2008
escapement
  • 2334 Answers
SOURCE: Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Posted on Mar 31, 2010
Testimonial: "Thanks so much. I thought I had tried what you suggested already, but apparently I hadn't. The watch is now set correctly. Thanks again!"
I've lost the instructions and can not reset it
Mate I googled the sekonda web site and this is the link-->
http://www.sekonda.co.uk/index.php?fuseaction=Static.faq
It's on the frequently asked questions page and if you click on the 10th question down (How do I use and adjust my Sekonda watch) a message drops down saying click HERE to download the sekonda instruction manual..... I hope this helps......CHEERS..
Mar 12, 2016 | Watches
What is the battery specification/type/spec for the Sekonda 3101 Men's writwatch
The practical answer is to take your watch to a jeweler who will not only open it but probably will install a replacement battery for a reasonable charge.
Mar 19, 2015 | Watches
Just trying to find an instruction manual for a wittnauer 2002 watch
This Watch has no Batteries Its a manual Automatic 15 jewel watch.
It has a perpetual calendar that is set manually by turning the bottom right stemIt has day which is set from center winding stemIt has date which is set by pressing the top right press pin
The easiest way to set the calender is to match the small red numbers(year 2000 and up)to the month at the bottom using the lower right stem.The top calender should show the right day against one of three dates
Value for a good one Up to 200 dollars in original box
Jun 04, 2011 | Watches
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
Nice Bruno Banani Chrono gent's watch. No instruction booklet arrived... How do I set date and day?
I cannot help with the day but the date can be set -
Pull the head of the crown fully , then push it back lightly half way and then rotate the crown.
hope this helps. If u get the solution for the date please do lemme know here.
May 03, 2010 | Watches
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
Apr 23, 2008 | Pulsar PXF106 Wrist Watch
Watches Logo
1,270 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
