Question about Magic Chef MCWC30MCG Compact Wine Cooler
MCWC45MCG it is a piece of junk from Whirlpool
Whirl Pool is also trying to hide the problem by not supporting it and going to MC
They are no help. Home Depot and Whirl Pool are to blame. Drop it back off at Home Depots door step that is what I did. Tell them thanks they can have it back.
Most importantly don't buy a Whirlpool product as they are the ones who started the whole mess.
The compressors are junk, don't let your place burn down because they don't care to help.
4 Suggested Answers
  • 640 Answers
SOURCE: whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Posted on Dec 25, 2008
  • 1998 Answers
SOURCE: i have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Apr 29, 2010
  • 910 Answers
SOURCE: I bought a Magic
E4 Indicates a fault with the DC Electric Fan on the Lower Zone.
As you've not had it a year I'd say your best option would be to get it fixed under warranty but if you want to look at it yourself.
If you take out the two screws on each side of the module tray and pull it out you'll see at the back of the tray a white and a black plug set. The black plug is for the top fan and the white plug is for bottom fan. It's a common fault that the pins errode due to moisture. If the pins are erroded you just need to cut off the plug rejoin the two wires with a terminal block which should solve your problem.
If the plugs/pins look OK then the fault is probably with the fan itself and I can look into a replacement if required.
If you require further assistance then please just ask.
Posted on Jul 19, 2011
Clutch for whirl pool 5 speed 9 cycle top loader washer
only available from a whirlpool service agent spares or from the whirlpool parts web page
Feb 06, 2017 | Whirlpool Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirl pool dryer is making a loud clicking noise
is it making a noise when going around if so something is stuck in the front or back bulk head making a clicking noisy as it is going around for example zipper or button of clothing
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
No power
The following link explains how to replace the drain pump on a Whirlpool Duet:
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whirl pool washer bangs when in spin cycle
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
the porcelain always remains white its the glow bar toward the end that will glow, you will need to check for power leading the ignitor, if indedd you have 110v, there replace ignitor very common issue with gas ranges
Nov 20, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Magic Chef MCWC30MCG Compact Wine Cooler Logo
207 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
