Question about Dell Office Equipment & Supplies
INK CARTRIDGES BANG TOGETHER WHEN PRINTING.... IT DOESNT HAPPEN ALL THE TIME, THEY MAKE A CLUNKING NOISE AND WONT PRINT...THEN SOMETIMES IT WILL BE FINE?....
    Scholar:
  • 97 Answers
Remove them and try to push them in again. They should click if they are seated properly and no lights should be flashing (unless you have refilled them).
Posted on Sep 25, 2009
Hi i have an epson stylus c64 and it hasnt been used in quite some time, i tried to print from it and it didnt work so i went and bought all new ink cartridges for it as i thought because it was stilling...
When printers sit for a long time, the ink in the cartridge dry-up as well as the ink in the printer orifices.
Since you replaced with new ink, then safe to assume the ink is dry and clogging the orifices.
You can pay for technician to attempt to clean but new printers are fairly inexpensive. Best bang for the buck would be to purchase a new printer.
Apr 01, 2011 | Office Equipment & Supplies
Makes clunking noise and wont print 1quarter of
scanner lamp is not working. can i buy replacement lamp.
Mar 08, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson CX 4300 printing problem
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
How to get my printer to print bw and color again?
the cartrdges contacts are well, the ink it is clogged in the printheads, take out the cartridges, put them in a wet towelwith windows cleaner liquid, just the head height, let rest 12 hours, clean and dry the heads and try to print, sometimes need a second time on liquid. good luck
Jul 29, 2009 | HP DeskJet 1220c InkJet Printer
Not printing
Here are the best instructions on how to clean the print cartridges.
Feb 25, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hp960C leaking ink
1. If you have them, go ahead and put on your latex or close fitting gloves. Ink generally gets everywhere and can be hard to clean off your hands. It’s important to not work on a printer that’s plugged in. However, sometimes certain inkjet printers will not let you change the ink unless the printer is plugged in. So, if this is the case, go ahead and life the cover of your inkjet so that the cartridges can be removed. Once that’s done, unplug the printer.
NOTE: Be sure not to touch the metal part of a inkjet cartridge, because the natural oils on your hand could inhibit the communication of your cartridge and your printer.
2.
To clean the inkjet cartridges, check to see if your cartridge’s have both ink and a print head together.
Together (most common):
Take a paper towel and fold it in fourths. Then add either alcohol (preferred) or Windex to one side of the paper towel. Now, wipe the bottom of the cartridge on the paper towel to clean off the print head in a flower like fashion. It is normal that ink comes out of the cartridge even after you think it’s all clean (that’s what it’s supposed to do).
Separate (less common):
Do not clean the ink cartridges themselves. Since they doesm’t have a print head and generally don’t control the amount of ink that flows out the bottom, you can get pretty messy if you tried to clean the ink itself. Take the print head and separate it from the ink cartridges, then follow the above directions to clean the head.
3.
Now take another paper towel and fold it again in fourths. This time spray a thin layer of Windex on the paper towel and clean the ribbon if it has any major ink blotches on it (see picture to better understand this step).
Whenever a printer finishes its document, your ink “rests” or docks usually on the right or left of the printer. Over time, this area can harness a ton of ink mixed with paper dust. This makes a gooey substance that’s can cause big image problems on the paper since every time you print, you run the chance of hitting or docking on this mountain of gooey ink. To clean, we’re not going to use a cleaner, because if you can see a buildup of ink, generally, it’s much too hard to get to and can be very messy. In the picture, I’ve highlighted where this printer’s “reserve” is starting to build up.
4.
After a while of printing, you may notice that the inside of your printer has a thin film of ink inside everywhere. Although it doesn’t really matter when it’s on the plastic, this can affect the oil on the stabilizing bar, making it harder and harder for the print heads to move. Sometimes it gets so bad that you can hear a “crunch” or “grind” and the end of a printing job. It may appear that the printer isn’t aligning right or can’t dock, but sometimes the lack of oil is the cause.
Jul 01, 2008 | HP DeskJet 960c InkJet Printer
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
