Question about Canon PowerShot A520 Digital Camera
After I put a new battery with in 5 minutes it shows the battery is dead
Battery life
There could be some internal short which is drianing the battery or your battery cell itself may be bad. Contact vendor if warrantee present.
Nov 19, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
I have been putting new expensive batteries in but is still spends a minute flashing orrange then flashes a red light and says "error" as if my batteries are dead??
Sep 11, 2011 | Sony HVL-F32X TTL Flash
I left the key on for about20 minutes and the battery went dead bump started the bike and did about 20 minutes of freeway driving battery did not charge. I brought the bike home and hooked a charger to it...
You can damage electrical components if you do not run the correct voltage battery. If your battery is below 12 volts replace it. If you take off the seat you can easily test the stator with a volt meter. Find the stator plug with three yellow wires. You should have continuity between any combination of the yellow wires. You should have no continuity between any of the yellow wires and ground. That is the test of a good stator. If your bike is still losing charge after those checks , you are probably looking at a new regulator/rectifier.
Oct 13, 2010 | 1979 Honda CX 500 A
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
Both batteries show full charge but don't last 10 minutes. Only had the tool for less than a year.
rechargeable batteries can build a memory, if you use it say for 5 minutes and then put it back on the charger - then the next time you use it for 5 screws and put it back on the charge - see where I am going
Over time the rechargeable batteries "learn" they only have to work for 5 minutes ( dang my son was that way)
You need to fully drain them and recharge them fully several times might take 10 times.
We have a program in our shop that when you are done with a battery it goes in the flashlight until dead, dead, dead then to the charger. I have batteries that are 10 years old and still work almost like new.
You may have to replace yours but it is worth a try
Mar 09, 2010 | Makita Cordless Impact Driver Kit
Battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Sep 20, 2009 | Computers & Internet
Camera will not stay on
Every time I put in a new battery it will only last about 5 or 10 minutes and then it says the battery is dead.
Jan 23, 2009 | Kodak EasyShare V705 Digital Camera
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Canon PowerShot A520 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
