Question about Minolta PagePro 1250W Laser Printer
I used to know what the toner level is. I can not find the way to display this information
  • Minolta Master
  • 6,161 Answers
How do I get a toner coverage report from a Sharp 2610C?
How do I monitor toner levels in my Sharp copier or MFP? You can monitor the toner levels in your Sharp copier or MFP by pressing and holding down the COPY function key . Two pieces of information will then be displayed.
The Total Copy count on the device
and
The remaining toner levels. This will be shown in 25% increments. When you get down to 25% capacity check to see if you have spare toner on hand. If not, give us a call and we will promptly deliver.
How do monitor toner levels in my Sharp copier or MFP
check out the user manual too:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwja6dWd9fLMAhXGlx4KHegRC24QFghIMAc&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Fmx3610nManual.pdf&usg=AFQjCNEyIj_mysubFXRIlvDoqEKBw3L4zQ&sig2=0jtdA8-CGBc2ej3tWvEdHg
it stated
To view the approximate amount of toner remaining, continually touch the [Home Screen] key ....
May 24, 2016 | Sharp Office Equipment & Supplies
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
CHECK TONER MC
Hello
This means your ink level is low but you can confirm this by doing the following;
.The Lexmark C500n uses powdered ink, called toner, like other laser printers. The printer creates a magnetic charge on the paper as it passes through the machine, forming text and images on the page. The printer then applies pressure and heat to the paper, fusing the powdered ink to the page so it will not smudge or run. At any time, you can check the amount of ink left in the printer's toner cartridge by printing a status page. This page will also show a tally of the number of pages printed by the machine, among other information.
Turn on the printer and let it warm up. Ensure the light next to "Ready" illuminates.
Press the "Go" button, or the button with the icon of the hand pressing a button. Use the arrow button on the printer's control panel to highlight "Test Menu," then press the button with the check mark.
Press the arrow button until you highlight "Status Page" on the printer's display panel. Wait as the printer generates a status page.
Retrieve the status page from the printer's output tray.
By doing this you will know the level of your toner.
Oct 23, 2010 | Lexmark C500n Laser Printer
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
We do not actually know, it just says replace supplies, does this mean all of our cartridges?
Yours is a network printer. Log into it using Internet Explorer using it's network address (typically http://192.168.1.xxx and it will give you the levels for each toner. On mine which isn't the same model the LCD has 4 colour bars and a display of the levels above the each bar. To prolong toner life check the recalibration menu and make it as infrequent as possible
Jun 30, 2009 | HP Laserjet Cp2025n Printer
Supply status
The operator panel on the 5110 ALWAYS displays the supply status of the toners. Each of the 4 colors, represented by a colored tear drop, black, cyan, magenta, and yellow are represented by a bar graph directly above the tear drop.
When all of the toners are full, all 4 bar graphs are displayed evenly. As toner is depleated, the bar graphs will decrease in size. When they are almost empty they will start to display an error code on the display to alert you.
Sep 22, 2008 | Dell 5110cn Laser Printer
Minolta PagePro 1250W Laser Printer Logo
26 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
