Question about Garden
Replaced motor case now blade run backward ryobi ap1301
  • 1 more comment
  • galoott Sep 25, 2009
    I have switch the wires at the switch and no change
    replaced motor case now blade runs backward ryobi ap1301 i have reversed the wires running into the motor still backwards
    the motor is belt driven directly to the cutter spindle can only go in one way the roller assembly was not removed
    President:
  • 1,653 Answers
There is only 1 way that this can happen and that is if you have removed the worm gears and oput them back in the wrong places which will make the feed rollers run in reverse and / or the cutting blade turn in reverse. The only other way is if somehow you managed to get the gearbox in backwards or inserted the motor in the wrong way around. Also check the motor wiring is the correct polarity.
Posted on Sep 25, 2009
  • Karl Wright
    Karl Wright Sep 25, 2009
    Assuming that this unit worked before you replaced the motor casing there is nothing else that can cause this. Why did you replace the motor case?
    President:
  • 1,714 Answers
You have reversed the polarity of the voltage to the motor. When you changed the case around, you must have changed the wires going into the motor? Reverse them back and motor will change directions for you.
  • Craig Butler
    Craig Butler Sep 25, 2009
    You didn't switch the right wires then. A DC motor changes direction when you change the polarity to the armature, or the field.
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Ryobi hedge trimmer found a sharp noise coming from driven motor. It started during a trimming job. Sounds like a sand between two reciprocating blades, but I am more afraid of a motor issue.
Either get the necessary tools or consider repair/replacement.
See if you can remove the blade and run motor to see if noise still continues.
Aug 24, 2015 | Ryobi Garden
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 | Garden
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
The saw wants to start backwards.
this confuses me. What do you mean it starts backwards? How do you know it is running backwards? how long have you had this tool? I am confused because it is a table saw. The motor should drive the blade in the direction the teeth are facing. Meaning the poity part of the blade is where the wood is to star its cut. If this is not the case, you either have the blade in backwards, or your standing on the wrong side of the saw. good luck.
Mar 04, 2010 | Bosch 4000 - 07 Electric Table Saws
Mowing blade turning the wrong direction
I think you did diagnose the problem. A DC motor will run backwards if the wires are switched around and polarity is reversed. Try switching the wires
Jul 02, 2009 | Garden
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
