Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Same issue Recognizes the printer when plugged in, but does not print anything. Also have used a paralell to USB cable.
  • erynsma29 Sep 25, 2009
    Thank you for your response!
    1)The printer is turned on.
    2) I do have two cables- the parallel cable and the connecting bidirectional USB cable. Have also tried swapping out both cables; that didn't work either.
    3)I have tried using both the driver from the website and the "add new hardware" setting".
    4) I left it disconnected until the driver was installed.
    Scholar:
  • 97 Answers
Is it switched on?
Do you have two cables going to it and is each plugged i n at each end?
Have you tried using your "Add New Hardware" setting?
When you installed your printer, did you install it BEFORE plugging it in? Try uninstalling your printer and reinstalling it again (with the printer unplugged) and then follow the directions.
Posted on Sep 25, 2009
C1110B print not clear
If you have not yet solved this issue , advise if you are on a paralell cable or usb cable connection? If it is a paralell connection pull the cable out and check for a bent pin, if affirmative straighten it out with small thin head pliers. If usb check that the correct driver has been loaded on the virtual usb port. Good Luck Ed Pinero
Jun 07, 2012 | Fuji DocuPrint C1110B Laser Printer
Paralell print cable to usb adapter
go to your control panel & delete the printer, shut down & restart turn the printer on after restart see if the computer sees the printer if not try reinstalling if this doesn't work possibly the adaptor
Dec 22, 2011 | HEWLETT-PACKARD LaserJet 6P / 6MP (H3966A)...
Will a sharp al 1451 copier printer using paralel cable and old windows operating sysytem be able to upgrade to new computor with windows 7 and using a usb to paralel cable ?
I would say it should. But go to the sharp.com site and type in the printer name in the search box and follow the site to the print drivers. I service a gazillion of those in a hospital and they adapt well to new OS and applications.
Mar 30, 2010 | Sharp AL-1451 Laser Printer
The media is in correctly and is being fed correctly but when we sent a label from our computer to the zebra printer it will not print the information on the media. Was fine a few days ago.
send a test print from the driver.
check the connection configuration.
if connect with serial port (check seting from the port (THE SPEED HAVE TO BE THE SAME)
if connect with USB, if necessery, install the driver again and test.
if necessery flash the firmware and test (worst case scenario)
if can't comunicate and if using paralel port:
check if the fuse next to the paralel port is burn ( on the logic board.). replace it.
dont forget to unplug the power cable and the comunication cable.
Nov 18, 2009 | Zebra 110XiIIIPlus Label Printer
I have a hp940c printer that worked great in Vista premium, but using windows7 platform recognizes it but I can't print from it. I don't think there exists drivers for windows7 yet, but is there anything I...
I just looked on my windows 7 box and I see that windows has 2 built in driver versions listed for that printer. Try removing the HP software for it (if its installed) and remove the printer from "printers and devices". If the printer is hooked up with USB, unplug the USB connection from the computer and plug it back in. If its hooked up with a parallel cable, use the add a printer wizard from within the devices and printers window. I had an hp printer issue after I upgraded from vista to 7. removing the printer and having windows reinstall it fixed it for me.
Nov 15, 2009 | HP DeskJet 940c InkJet Printer
Dell 720 printer
Delete the printer icon and disconnect the USB cable. Restart the laptop, reconnect the USB cable to see if your laptop recognizes the printer. If so, install the printer driver. If not, probably USB cable or port issue. Hope this helps.
Aug 05, 2009 | Dell Inkjet 720 Printer
Recognizes printer, won't print
What i'm getting at is if the printer was not used for a long time the cartridges may have dried out.
Robert
Aug 30, 2008 | HP Photosmart 8250 InkJet Printer
Won't print from usb or parrallel cable
check the usb sucket on the printer board and see if the legs are firm if ok check the board
Jul 19, 2008 | Brother HL 5140 Laser Printer
Slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: decoy424@gmail.com
Feb 03, 2008 | Canon BJC 80 InkJet Printer
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
