NEC ,model no. PJ-4650EN Projection
My NEC ,model no. PJ-4650EN picture is still blurry even after I've cleaned the lenses assuming it would help. The TV works great, but is there anything I can do to better the picture quality before bringing it to a repair shop?
    President:
  • 1,779 Answers
If you look into the Len's of each tube briefly when it is on and look at the quality of the picture. It sounds like the fluid is bad and should be replaced by a service company.
Posted on Sep 25, 2009
Blurry picture how do a make picture clean and sharp? language in chinese how do i make english?
Check if lenses and mirrors are dirty. If necesary clean with a soft cloth using a solution 50% isoprop. alcohol and 50% oxygen water. This could be the cause the image is blurred.
Feb 19, 2011 | Samsung PCH521R 52" Rear Projection...
My picture is blurry
hi there.you need to remove the screen and clean the dust off the three lenses,which causes this problem. best wishes, steve
Sep 11, 2010 | Sony KP-61HS10 61" Rear Projection...
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Blurry picture
if the blur is all over the screen, it may be as simple as cleaning the mirror and the lenses
Sep 06, 2009 | Sony KP-61HS10 61" Rear Projection...
Old projection tv NEC PJ-60PI circa 1972
You will want to find a local servicer for an honest tech to come out and check for bad connections on boards. It will be hard to find someone for a 1972 unit and parts even harder. If you are near Cleveland, I can help
Craig www.classtorations.com
Jun 08, 2008 | Televison & Video
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
