Question about Plumbing
I recently bought a Jebao WP-650 Low Voltage Submersible Water Feature Pump which came without instructions. Do you know how to clean the filter on this product, or even if it has a filter?
Quack
  • 542 Answers
SOURCE: Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Posted on Aug 30, 2005
22yooper
  • 828 Answers
SOURCE: KM 280MAH
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Posted on Sep 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFL 2060 Washer pump issue
If the pump is working then you will not need a new board..
Remove the pump from the m/c, connect live and neutral supply to the pump, it should run.
If it does then your problem could be an internal blockage in the m/c.
Hope this helps
Posted on Dec 03, 2008
  • 1348 Answers
SOURCE: Low Mileage
clean the throttle body.the throttle body can get gummed up and cause issues.
put a fuel additive to clean the system.
these other items all contribute to fuel usage.
spark plugs.
o2 sensor
air flow meter
fuel filter
idle air controller (IAC)
Posted on May 13, 2009
XPoolGuy
  • 34 Answers
SOURCE: No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Posted on Jul 04, 2009
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
I recently filled my Clearwater Spa with water, cleaned the filter and turned it on. I think the Z0-300 ozonator purple light was on when I first powered it up, but am not certain. The Balboa DE-L201...
check voltage to low speed pump if ok bad pump with all pumps going its moving water to heat when on low only not enough pressure check recirculation pump also its connected to heater
May 10, 2017 | Balboa Instruments Duplex Digital Panel 2...
No water from well.
If the water pressure reads 50 psi, then, the submersible pump is running okey. Do these:
1. Shut the power off.
2. Release the pressure of the tank by opening the
gate valve and free the air inside.
3.Drain the water inside your pressure tank empty by
opening the drain plug at the bottom.
4. Then, replace the drain plug .
5. Check the flow control valve. From full close
position, adjust to 1/4 open position. However, if it
is using a gate valve as flow control, Just open two
full turn counter clockwise.
6. Put the power on.
7. And start the submersible pump and allow it to
run until the pressure tank is pressurized.
8. At 20 psi pressure, open your faucet, and see if
you've got water.
I would like to know the result, so just send in your e-mail . Thanks and God bless you.
6.
Oct 26, 2009 | Plumbing
Ecoplus 230 surface pump plugged. Is there a filter or debris screen to clean? pump is primed. runs without excess noise. no water out the outlet port
Hi ! Nothing to clean on this, just make it pump some hydroponics cleaning pump products with distilled water to remove the deposit without taking risk to damage your system/plants. Thanks and have a nice day J -
Oct 24, 2009 | National EcoPlus 100 GPH Submersible Water...
Is it possible that my well is going dry? second submersible pump I've burned up 1/1/4 hp gould pump lasted less than one mouth
several things will affect the pump, has there been a lot less rain than normal or using a lot more water such as more showers and toilet flushing ? if no then something else is wrong. the pump should3 feet from bottom of the well and should have roughly 10 feet of water above. when pump was replaced did they put it low enough in the well? The capacitor and wiring are they in good shape and supplying enough power? if voltage is low such as bigger pump or long wire run, too small a wire the voltage can become to low and cause pump failure. suggest having wiring tested first (cheapest) if all fine from there need to check water level and pump depth setting.
Jul 10, 2009 | Craftsman Professional 1/4 Hp Submersible...
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Plumbing Logo
966 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
