Question about SimpleTech 160GB USB 2.0 / FireWire External Open Box (STIU2F36160OBB1) Hard Drive
My simple tech 320 gb will not work with my sony laptop. the laptop will not recognize it. It works with the dell computers at my school. what is the problem?
4 Suggested Answers
  • 8 Answers
SOURCE: simple tech mini 320 gb external hard drive
You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Posted on Jun 05, 2008
  • 8 Answers
SOURCE: Simple Tech 320
Select “Manage”
  • 13 Answers
SOURCE: My Simple Tech 320 GB
Well the drive is finished, but you can still take it to a computer shop who can open the casing and pop in a new 2.5inch drive, it will cost you less than buying a new one.
Posted on Jun 03, 2011
RAM PROBLEM ON INSPIRON N4010
Go into your BIOS and set it back to factory default. After you do that look at the page that lists your memory and see if both 2GB memory sticks are recognized. If one of them still isn't being recognized. You'll have to physically go inside of the computer and look at your memory slots to see how much memory is in each slot. Its possible you might not see both 2 GB memory sticks. If you do see both then one of them might be bad and you would need to talk to that tech shop to get it replaced.
Feb 06, 2012 | Dell Inspiron N4010 Notebook
What is the maximum Hard Drive upgrade posible for Dell inspiron 630M?
Your BIOS will only see 137 GB. at a time. I installed a 320 gb. but I had to partition it into 130 gb and 190 gb.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Dell Inspiron 630M Notebook
Other computers will not recognize my hard drive
which file systen did you format with NTFS or FAT32 and what file system is your school? If it dont match it wont read. NTFS will read FAT32 but not other way round
Jul 02, 2010 | Western Digital Elements powered by WD 320...
My Transcend StoreJet 320 GB USB 20 Hard Drive is having a problem When i connected the drive to my laptop it got detected for sometime and then disconnected automatically
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Dell laptop showing blue screen of death while playing any movie in the cd/dvd drive ? this is happening mostly when I am powering my laptop with the adapter. Dell new inspiron 14 (320 gb HD, 2 gb RAM and...
You are missing an important startup script in the computer and you will need to install the drivers to make it work you will go on dell search drivers put in the serial and model and all the drivers will be there..
Please Rate High If I helped Cause It Helps Me
Thanks.... Nick
Apr 26, 2010 | Dell Computers & Internet
Dell Inspiron 2650 laptop is not recognizing hard drive
Do you have the dell diags cd that came with the computer.If you do ,boot to the cd and run a diag.Once in the menue do a quick test,check the device you want to check and wait for the result.You may want to test all devices since you want to make sure the computer is working and you might have only a failed hard drive.
Feb 22, 2009 | SimpleTech (STT440HD/40) 40 GB Hard Drive
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech mini 320 gb external hard drive
It mostly comes with 3 years of warranty but you cant utilise warranty just for being "not recognized".
Try to trouble shoot the problem by using the technical suppport offered for the item
Apr 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
32 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
