Question about HP PhotoSmart 1215 InkJet Printer
Keep getting Margin error code about text being outside the set 1 setting?
    Scholar:
  • 97 Answers
Try widening your margins a bit or using the "shrink to fit" setting in your word processor.
Posted on Sep 25, 2009
Restore dell d620 to factory settings without CD
How to restore your computer to factorysettings without a disk?
If original andfairly new: While Booting Up.
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come withdisks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever putanything on the recovery partition d:, if you used d: for anything you need toremove what you put there or the recovery will not function.(As soon as yourcomputer is turning on press the F10 key and it will take you to the systemrecovery screen, click on the advanced option and click Destructive recoveryand click next. WARNING: before doing this backup anything on your computer youwant to keep pictures, videos, music etc. This will delete everything that didnot come pre-loaded from the factory, so if you have pictures of Aunt Fae'sClass reunion you should probably back those up if you want to keep them.)
Sep 24, 2011 | Dell Latitude D620 Notebook
I can't get my computer to print because it keeps saying the margins of section 1 are set outside the printable area of the page. I have a meeting to go to and It's important that I get this paper off the...
I assume this error is occuring in Microsoft Word.
  1. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  2. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  3. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  4. Click OK.
May 12, 2010 | HP Officejet J5780 All-In-One Printer
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
How to set margins on Olympia compact s - is there a manual available?
use the "margin left" key to set left margin, and the "Margin Right" key to set the right margin. Move to where you want the margin to be and press the right or left margin keys. to go beyond a margin (to set margins "outside" the current settings, press the MAR REL (Margin Release) button while at the current margin
Oct 02, 2009 | Olympia Office Equipment & Supplies
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Margins will not hold, have to keep resetting them.
Auto margins are permanently stored in the Swintec 8014S. If you set new margins within those margins, they should hold. If you set them outside of the auto margins you will have to use the MAR REL key to release the auto margins, and then set the new margins. All margins are set by pressing the Left or Right Margin Set keys.
These settings are stored in a memory circuit that is powered by a battery that is automatically charged when the typewriter power is on. If you still have trouble with the margins releasing after you turn off the machine, you can try one of the following:
(1) Keep your typewriter on for a couple of hours so the battery can recharge and then save your margin settings
(2) Replace the battery which may have died after all these years. You would need to bring your Swintec to a local dealer for the part and replacement service.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 06, 2009 | Swintec Office Equipment & Supplies
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Feb 06, 2009 | Brother ML-300 Typewriter
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Unable to set margins
To set the Left margin:
1) Move the carrier ro the place you want to set the left margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current left margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[L MAR(4)]. The left margin is now set.
To set the Right margin:
1) Move the carrier ro the place you want to set the right margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current right margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[R MAR(5)]. The right margin is now set.
That is directly out of the manual. I will upload the manual to FixYa, and you will be able to view it from the ML-500 Typewriter's product page: http://www.fixya.com/support/p131634-brother_ml_500_typewriter
-John
Feb 06, 2008 | Brother ML-500 Typewriter
HP PhotoSmart 1215 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
