Question about GE Refrigerators
Water in bottom of refrigerator has to be removed every couple of days or will come out onto the floor.
  • 193 Answers
Under the vegetable tray, a small drain hole is stopped up.Everytime you unit goes into defrost mode,the water is not draining to the defrost tray under unit
Posted on Sep 29, 2009
  • GE Master
  • 1,606 Answers
Your defrost drain is stopped up in the freezer section . Remove the food and ice maker , if equipped , and remove the inside rear freezer panel . Use a hair dryer , starting in the center , below the coils , and defrost the ice under the coils , until you see the drain hole . Use hot water to help defrost the hole . When water starts to flow into the drain , use a small hose , inserted into the drain , and blow thru it , to remove any unseen debris in the drain line . Remove the rest of the ice in trough , and reassemble the freezer .
4 Suggested Answers
Tech007
  • 63 Answers
SOURCE: water in bottom of fridge
THE DRIAN HOLE IS CLOGGED ITS IN FREZZOR IN THE BACK BEHIND THE BACK PANEL BUT YOU CAN LOOK UNDER THE FRIDGE AND FIND THE OTHER END OF THE DRIAN HOSE BLOW AIR TROUGH IT TO CLEAN IT OUT MAKE SURE THE FRIDG IS OFF FOR A DAY, OPEN FREEZOR DOOR TO MELT ICE IN DRIAN HOLE AND HOSE AIR PRESSOR MAY NOT BLOW THE ICE BLOCKAGE OUT DEFROST FOR A DAY THEN IT WILL CLEAN UP NICE
Posted on Aug 30, 2007
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE
You will need to get that panel out of the way to see and clean out the defrost drain.
Click Here=>Leaking Refrigerators
I am here should have questions, Thanks John Tripp Appliance 911
Jul 23, 2014 | Maytag 22 cu. ft. Bottom Freezer...
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
Water in bottom of fridge
Aug 29, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
