Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Computer audio not working with my toshiba regza
I have my computer connected to my toshiba regza, in fact, i'm currently accessing this website through it, but i can't seem to get the audio to work. its connected via my computer's audio-out to the tv's pc/hdmi (audio) in. is there a driver i need to download?
  • rahat faraz May 11, 2010
    Solution chack on this site www.solve.tk
  • 4 Answers
SOURCE: HD set top box to PC via HDMI
it should be an HDMI Output, you should be able to hook up to a monitor with no problems but directly to a PC, not so much. In what way will you be using this application, that may help
Posted on Apr 29, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
  • 1039 Answers
SOURCE: Toshiba REGZA 37AV500A LCD TV
Does this happen with all the HDMI inputs. If only the one then jack is bad. Replace the main board. If on all HDMI inputs see if replacing the cable helps.
Posted on Nov 09, 2009
tvtek
  • 1284 Answers
SOURCE: toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Posted on Nov 20, 2009
JulesPCaut
  • 702 Answers
SOURCE: connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
Posted on Dec 03, 2010
How do I connect a Goodmans sound bar to my Toshiba Regza tv as the manual says connect via Aux
hook the soundbar to your axillary output or audio output or speaker output
Jan 08, 2015 | Toshiba Televison & Video
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
How do i connect a surround sound system to my Toshiba Regza 32L TV
If you look at this image: http://i.testfreaks.co.uk/images/products/600x400/251/toshiba-regza-32c3030d.3770363.jpg
The back of your tv should be similar to this (I couldn't find an exact one, but it should be very similar). You want to plug in your audio cables into the red and white plugs at the bottom right, and then into your surround sound. This should work (assuming they are the same layout).
If they are different, try and find a set of red and white plugs that say "Audio out" and "L + R" or something similar to that. These plugs will work.
Feb 28, 2011 | Toshiba Audio Players & Recorders
Hi, i have a lcd toshiba regza LV733N, and i get no audio when connected to pc on hdmi connection. but i do get audio on the same hdmi cable when is connected to my ps3. on a lcd panasonic, both the video...
You must use HDMI 1 port when conected to a PC (to have a picture). Also set the audio in to HDMI not to PC. Look at SOUND/ADVANCED AUDIO. You can use separate analog cable also... Please just read the F manual
Feb 12, 2011 | Televison & Video
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
Cc1 changes to cc3 automatically so cc comes on/off autonatically.
YOU MAY NEED TO UPDATE TO MOST CURRENT SOFTWARE FROM TOSHIBA WEBSITE. CONTACT TOSHIBA OR CHECK THE SUPPORT WEBSITE TO SEE IF CUSTOMER SOFTWARE UPDATES ARE POSSIBLE.
Dec 17, 2010 | Toshiba REGZA 52RV530U LCD TV
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Televison & Video
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
