Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Have a Samsung SyncMaster 225bw. Noticed lately that when I turn on monitor and computer, the monitor does not show anything even once computer has completed bootup phase. The power button is blinking on and off continuously on the monitor and after a awhile (2-3 mins), the screen finally starts to phase into a white wash....I will normally have to turn it off and on and then I get my picture coming up from desktop as it flickers for about a minute until it stops (starts fast and slows down) and eventually the screen brightens up and I can work with it normally.... This just seems like the screen is about dead....any advice?
  • 1 more comment
  • Dyderich Sep 28, 2009
    dvi connection on computer to standard serial on monitor itself....
    nVidia 8800 x2
    Monitor totally died yesterday night...I had to replace it with one of my standby CRTs....what a horrible difference now...especially with going from 22" to 17" again.
    Will end up replacing the monitor with a new one...
  • Buddy Mcsparrin May 11, 2010
    Hello, The Samsung 225BW has a known issue with the backlight power supply going out. The dark screen with green power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com I hope this helps, if so please rate our solution. Buddy Corporate Computer www.ccl-la.com
  • kat_se_snor May 11, 2010
    It sounds a bit dodgy. I have a Samsung 2232gw. What graphics card do you have, and do you connect it via vga or dvi?
  • 80 Answers
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Posted on May 15, 2010
    Novelist:
  • 152 Answers
Dyderich, Yes, You should read up on all the causes of LCD monitor failures!! Your symptom will be among the top three cause/complaint of failures. LCD units can be repaired. If you have never used a soldering pencil, digital volt meter, DMM or Oscilloscope, then you should keep yur gruby fingers on the outside of the monitor. Your monitor's "switch-mode-power-supply" and the "cold-cathode-fluorescent-tube's" and the "inveter" power supply that lights up the tubes will need to be evaluated(trouble shoot) by a TECHNICIAN who knows all there is to know about CCFT's and what it takes to get them to light up!!! Or you can trade up to a younger model, and repair/refurbish the old and keep as a spare. You could also see if SAMSUNG has some sort of swapout program for newly refurbished same model monitors? ? ? Check with a Samsung dealer and or their website. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 25, 2009
Samsung Syncmaster 225BW startup problem
reinstall the driver. what was the last update that you applied in general. revert back to LKGC last known good configuration.
Mar 07, 2014 | Samsung SyncMaster 225BW 22-Inch LCD...
I have a SyncMaster 225bw, approx 3 years old but havnt used it much in the last year and a half. it started having a problem starting back up it seems. if i can get it to stay "lit up" it will...
This type of monitor problem is usually cause by a failure of the capacitors in the power supply board. What is happening is the power supply is not starting up correctly so the back lights are not coming up to full brightness. Here is a link to a repair guide that will show you how to dis-assemble the unit and repair the power supply board. http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
If you can do a little soldering then you can do the repair yourself.
Apr 15, 2011 | Samsung 225BW LCD Monitor
My SyncMaster 225BW 22 inch does unpredictable displays when my PC is first started up, or awakes from sleep mode. (display is shifted to the right, or brightness is stuck on very low, etc.). Before, I...
The brightness issues with this model are usually caused by a power supply that is starting to fail. There are parts called capacitors that start to fail, when this happens the power supply can not get to the correct voltage outputs that it needs to properly run the back light bulbs. This type of problem causes either the dim display that you have or a wavy display until the unit can stabilize the output voltage. It is repairable if you can do a little soldering. You will need to replace the 5 capacitors on the power supply board. Here is a link to a repair guide for that unit that shows what needs to be replaced.
This is an easy fix, about 15 minutes once you have the parts.
Feb 04, 2011 | Samsung 225BW LCD Monitor
How to open a Samsung 225bw besides just removing the screws?
Here is a link to a repair guide that shows how to dis-assemble the unit.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 12, 2010 | Samsung 225BW Monitor
Monitor is ghosting, white trails.
You might want to try detaching the monitor and trying it on another computer unit to see if the problem still exists.  If it only occurs on your unit, then try updating the drivers on your system and see if that solves it.
Jun 30, 2010 | Samsung 225BW Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
Samsung syncmaster 226BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
Prior to this past week my Samsung SyncMaster 225BW monitor's display came on almost instantly when turned on. Now it takes at least 30 seconds to reach full brightness. What is the most likely cause ...
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Dec 16, 2009 | Samsung Computers & Internet
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
I have a samsung syncmaster 932B, it worked fine, then when i turned it on it turns on and after a second it turns back off, then i noticed that it shows but its very very dark, i saw some colors but still...
If you look very closely at the screen with the computer on, you may be able to see the desktop etc. but very dark. If this is so, then the blacklight is not working most probably caused but the inverter failing. This can be repaired but is best left to a professional.
If you wanted to fix it this yourself then Google for the inverter data and instructions on how to open the monitors case etc.
Nov 01, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
2,540 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
