Question about Microsoft Xbox 360 Console
No component cable audio?
I cannot get audio from my component cable on my xbox 360?
  • james_curran Sep 25, 2009
    I hook up the 3 color coordinated component cables and the red and white audio cables and I cannot get any audio but I do have a beautiful picture. I've bought a new set of cable, and that didn't work. My receiver is hooked up to my tv and I have great surround sound for all hook ups except my newly aquired xbox 360.
  • Cary Farah
    Cary Farah May 11, 2010
    http://www.llamma.com/xbox/Repairs/repai...
  • 27 Answers
HD colour wires are: red green and blue
normal are: red yellow white
Posted on Sep 26, 2009
4 Suggested Answers
SOURCE: XBOX 360 Elite HDMI problem
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 25, 2007
  • 133 Answers
SOURCE: xbox 360 audio is scratchy
It has to be reflown.. That's the only solution to fixing the audio problems , because its in the motherboard.
Posted on May 30, 2009
  • 143 Answers
SOURCE: my xbox 360 turns on, no audio or video
Sounds like the Graphic processor needs to be reflowed and new thermal compound (artic silver 5) installed. Its basically the same problem as the RROD just without the lights.
Posted on Dec 04, 2009
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
My xbox 360 turns on, no audio or video
Dec 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
I get red rings when i turn on my xbox 360
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
