Question about Dryers
Pressing the start button on my dryer produces only a faint buzzing sound and the dryer does not start. All electrical connections check by a licensed electrician and 240V measured at the outlet. Dryer was working perfectly until a recent move but there is no visible damage to the dryer from the move.
    President:
  • 1,922 Answers
Did I chat with you earlier today? about the possibility of the motor start capacitor being defective? hope you found it and were successful in the repairs
Posted on Sep 25, 2009
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 31, 2011 | Dryers
I have a Kenmore Elite electric dryer. It is only two years old. The dryer is a HE 3. Model 1108787 or 1108789. It was working fine two days ago then after finishing the dryer load it was on....I went to...
This could be one of several things.
1.thermal fuse is blown(with power off(unplugged)check for continuity)
2.Belt is broken (check belt).
3.loose wire somewhere
4.Door switch malfuntion push in on it and and test for continuity.
5.The control board is malfunctioning.Try removing it and observe the back of it for burnt or cracked places.
6.Motor is bad test for power to motor see wiring diagram and tech sheet inside cabinet.
Input full model # here for parts and diagrams. Model # should be located just inside of door.
searspartsdirect.com
Nov 03, 2010 | Dryers
Wont turn on, just buzzing sound
Sounds like a bad motor for you...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Dryer doesn't start
The faint sound seems normal. Sounds like it could be a thermal fuse. Also if the dryer is electric check your breaker box first.(there are two breaker fuses for electric dryers).... If one is blown then it may cause this problem....... Back to thermal fuse, they are easy to check... If not thermal fuse it could be the start switch or relay...... if you still have problems please respond back with model and make...
Mar 30, 2008 | Dryers
Dryers Logo
Top Dryers Experts
