Question about Kenmore Dishwashers
Turn on dishwasher hear noise but no water comes in
    President:
  • 942 Answers
Hi..
If the dishwasher is noisy you need to follow this;
  • Check the spray arm for damage and obstructions
  • Check the inlet filter screens
  • Test the water inlet valve
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow.
turn on dishwasher hear noise but no water comes - inletvalve.jpgThere are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
  • Check the motor and mounts
  • Check the fan motor and blade
  • Check the drain for obstructions
Good luck! Thanks of using fixya.
Regards
PCmania
Posted on Sep 25, 2009
Dishwasher is not washing
Possibly inlet hose line is blocked with crud from your water source. Please confirm by turning off water under sink, disconnecting hose under dishwasher and, WITH HOSE IN AN OLD MILK BOTTLE, slowly turn on water under sink to verify water flow. If ok, water inlet selenoid is blocked and needs to cleared (with compressed air). Alternatively, input seleniod is burned out and needs to be replaced.
Jan 05, 2012 | Whirlpool Dishwashers
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
Water will not come into the dishwasher
it may be stuckin drain mode. the float may be activated. remove any water that may have leaked in the machine. then check the water source make sure the water is going into unit. last check your water valve, ohms it out .that should it,if i helped please send me a 4 thumbs up post.Thanks!
Feb 21, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Intermittent loud noise
more than likely is the pump the noise your hearing is most likely the bearings or the coling bladed on the motor
Jul 26, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
The water is not coming into the machine and the tablet is still dry even though it comes out the draw, the dishwasher makes a noise but no water s getting into the machine
Check your water inlet hose and any filters attached to it. Some hoses have a little turnkey tab to turn them off. Make sure this has not accidently gone into the shut off position. If you pull out the machine you will hear if the water is coming in through the inlet hose.
Jun 18, 2009 | Dishwashers
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Dec 03, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Kenmore Elite Dishwasher
I have the same problem...did you ever get an answer on how to repair
Apr 07, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
52 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
