Question about Dell F3534 Touchpad
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
    Novelist:
  • 110 Answers
Is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
Posted on Sep 25, 2009
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Cannot turn on wireless capability on dell inspiron 1520. just changed from verizon to comcast
Try this,
In the bottom right corner of your desktop, is there a little picture of a computer screen with a couple of "sound waves" coming off it? If so, right click on it and a menu box will open with the choices;
Disable
Status
Repair
View available wireless networks
Change windows firewall settings
Open network Connections
choose view available wireless networksThen look for the comcast network and connect to that.
If Comcast isn't available on the list, you may have to choose and look in your LAN or high speed internet category to see if its listed there. If it is, right clik on it and choose
Dec 28, 2010 | Dell Inspiron E1405 Notebook
Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Nov 06, 2009 | Dell Inspiron 1520 Motherboard
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
Jul 11, 2009 | Dell Inspiron 1521 Laptop
Dell inspiron 1520 screen dim on left side
make sure there are no speakers at the side of the monitor as the may not be sheilded. then unplug monitor from the mains and plug back in to reset. or in the monitor menu select degauze .
Apr 05, 2009 | Dell Computers & Internet
Computers & Internet Logo
246 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
