Question about Kodak Photo Printer 6850 Thermal
There is a thin white line on every print in the same place
Blown pixel ? big repair bill
Posted on Nov 22, 2010
jaylex
  • 417 Answers
SOURCE: EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Posted on Jan 12, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Posted on Dec 26, 2008
murmerjoy
  • 805 Answers
SOURCE: white line across photo
clean ur printer head. and check that if any air ur ink box
Posted on Jul 21, 2009
  • 13 Answers
SOURCE: Prints have a thin white line across all the
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Posted on Oct 21, 2009
adracamas
  • 344 Answers
SOURCE: mitsubishi printer 3020dae. thin
You may either have a bad connection in the thermal array or dirt/dust on it. If you have never performed maintenance on the device you can find an easy button here http://www.cleanteam.com/Thermalcards.html
Otherwise if you feel brave, open her up! Turn off the power first of course. Grab a micro-fiber cloth (like for photo lens cleaning) and a bottle of at least 99% isopropylene alcohol.
Dampen the cloth with the alcohol (not super saturated) and with moderate to gentle pressure swipe the thermal strip (the cover is usually made of glass, be careful not to break it.) Repeat with a clean area of the cloth, dampen with alcohol, swipe. Do this several times and let sit to dry for at least 5 min.
Put her back together and you should be good to go!
Posted on Apr 05, 2011
White Lines over Black Colour?
MAKE PRINT ALIGNMENT
IF THE PROBLEM PRESENTS
FALLOW LINK
PIXMA MG5250
May 07, 2014 | Canon MG5250 Printer
Kodak 6800 white line down the print can it be fixed
I dont have a solution but I have the same problem with my Kodak 6800... a thin white line down the length of the print... can anybody help?
Feb 28, 2011 | Office Equipment & Supplies
Thin white lines on photos
Are the white lines horizontal or vertical?
Try to clean the contacts.
Horizontal lines = print carriage issue
Vertical = rollers
Feb 13, 2011 | HP Office Equipment & Supplies
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
White line across photo
Jul 21, 2009 | Dell 540 Photo Thermal Printer
Dec 26, 2008 | HP LaserJet 5p Printer
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
Open Questions:
See all Kodak Photo Printer 6850 Thermal Questions
Kodak Photo Printer 6850 Thermal Logo
163 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
