Question about Cycling
I HAVE A SUNLITE BOTTOM BRACKET CONVERSION KIT. HOW DO I INSTALL IT? IT ONLY HAS ONE LOCK WASHER. I KNOW I'M MISSING A REALLY SIMPLE STEP.
SOURCE: How to install Amana part number 12001937 Thermostat kit
I have a Sears Maytag with a cooling problem. Meat is frozen but bread is soft. I am told it is a Amana. It is a bottom freezer. Did this part fix your problem. Let me know, I am going to rip mine down in the am. Bandit98
Posted on Jan 26, 2008
FRANKSFIXIT
  • 72 Answers
SOURCE: Yamaha Generator YG4600D
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 07, 2008
  • 22 Answers
SOURCE: How to install flange conversion kit for 96 300tdi Land Rover Disco
does the kit come with gear or just flange ?
Posted on Oct 23, 2008
motor1258
  • 6674 Answers
SOURCE: install a clutch kit
This link may help.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528018f027
Posted on Feb 27, 2009
  • 226 Answers
SOURCE: cannot remove rear brake caliper
Try using a "c" clamp and push the piston in all the way on the caliper. Take the lid off the master cyl first. Lee
Posted on Oct 11, 2009
Sunlite bike cable lock. I opened the lock and now cant put the male end back into the lock because I forgot the combination
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination.
Apr 14, 2017 | Sunlite Cycling
How do I open the lock if I Forgot combo.
You could spend hours trying every combination, or cut the lock off and buy a new one.
Aug 20, 2014 | Sunlite Cycling
Converting cafe range to lp
http://www.davesrepair.com/DIYhelp/RngNAT-LPconv.htm
once you have the conversion kit, here is a simple procedure to follow to convert your range. Most conversion kits come with step-by-step instruction sheets. Also, use a piece of black electrical tape and fold it over the edge of the socket you'll use so that part of the tape is inside the socket. This will maintain a hold on the orifice when removing it so you don't drop it inside the stove top.
Jan 18, 2014 | GE Cafe CGS980S Kitchen Range
Keyless entry kit doesn't work
there is a positive and negative wire on your door lock motor. you need to put the purple wire to the negitve wire going to your door lock. try hooking up to just one of the door locks neg wires. if it only unlocks that door then you will need to run wires to the other doors aswell. the keyless system sends a neg pulse to unlock and lock the posiytive is constant. so unhook purple and attach to lock ground not car ground
Mar 17, 2013 | 2006 Nissan Sentra
Ge wpre6100g0wt washer squeaking
Basically the apron bends down to the point that the bottom of the motor bracket hits the bottom of the washer when it agitates. If this is the case you have the sagging apron issue. The kit comes with good installation instructions that are pretty much straight forward. Here is the kit to order.
Nov 20, 2012 | Washing Machines
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Jun 30, 2011 | Sunlite Coil Cable Resettable Combination...
My altenator bolt broke off in the block i bustted out the boilthole with a 3/8 drillbite is there a way to put a screw threw the hole & boilt it down on both ends & will it hold without brakeing...
If you have threads left in the block you can buy a STUD. The stud has threads to go into the block, then a little lip (stops it from going in to far)
then more threads. slide the bracket over the stud and put a lock washer and nut on. Buy the right Length stud.
Jan 28, 2010 | 2001 Acura 3.2TL
Morigeau Lepine conversion kit needed
I also had the same problem of finding the conversion kit for 5000 series crib in chocolate. I have been trying everywhere and finally I came across this baby furniture store in San Diego. I contacted them, drove up to San Diego from Orange County and got my conversion kit last weekend. You guys might want to give it a try. Contact Mory at Children's Land, http://www.childrensland.net/ tel:858-689-9998. They have conversion for many types of morigeau lepine's cribs.
Mar 03, 2009 | Pali Katie Crib
I NEED TO REMOVE THE DOORS
Removing doors can be tricky... if you need to reinstall them.
First remove the plastic cover top door if it's an over under. Usually the screws are 5/16 there are 3 screws usually. Remove 2 screws loosen up the third. swing the bracket out of the way. Reinstall the screws you removed, this keeps interior screw plate in place and does not allow it to shift. Remove the 3rd screw , Remove the bracket reinstall the 3rd screw.
lift up and remove the door rememder washer locations.
Is there a washer on top of the middle bracket? Do not loose this or get it confussed with the bottom washer on the bottom bracket. Next there should be 2 screws on the middle braclet.
Remove one, loosen the other swing the bracket around. Install the removed screw. Remove the second screw. Remove the bracket, reinstall the screw. Lift bottom door up remove.
Now do the same to the bottom bracket. Or do not remove the bottom bracket if you don't have to. hope thisd helps.
Jun 01, 2008 | KitchenAid Refrigerators
Cycling Logo
107 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
