Question about Garden
Where do i put the soap?
I bought some 30 second soap for my excell 2600 presure washer and dont know were to put the soap.
SOURCE: pressure washer - can't figure out soap
Use your mouth to get the siphon started. That's what I did and mine worked great!
Posted on May 23, 2009
  • 760 Answers
SOURCE: excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Posted on Jul 25, 2010
Testimonial: "thanks, funoldman i will check that out.....good info"
  • 8 Answers
SOURCE: Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
heatman101
  • 43501 Answers
SOURCE: Water is exiting the washer through the soap tank
The check valve in the hose from the soap tank is bad or has dirt in it...this allows the water to back through the hose into the tank. Replace the check valve and all will be well again...
heatman101
Posted on Jul 05, 2011
  • 6468 Answers
SOURCE: homelite presure washers wy my presure washer only start if i put a litle bit of gas true the carburator but dont stay on
sounds to me like some of the jets in the cab are plugged remove the carb and clean the jets and passages
Posted on Aug 12, 2012
The presure washer head will not turn or will stop turner when engaged
The head probably needs some cleaning. I use a spray bottle of general cleaner. Then I'll shoot some wd40 in the head.
Jun 09, 2014 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Homelite presure washers wy my presure washer only start if i put a litle bit of gas true the carburator but dont stay on
Aug 08, 2012 | Garden
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Excell r 2522 presure washer pump rebuild
Jul 25, 2010 | Honda Garden
Huskey pressure washer 2600 the water works but not the soap dispenser
Hello kjc33;
Do you know that the unit must be on low pressure to apply soap. The control is usually on the nozzle
Jul 11, 2009 | Garden
Pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Apr 09, 2009 | House Brand Garden
Soap not emptied
The soap tray has a plastic separator which has one position for liquid soap (the separator goes to the bottom of the tray).
It has a second position in which the separator leave a gap at the bottom so the powder can be flushed through.
I had put powder in the liquid setting and thus the soap did not get flushed into the washer.
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
