Question about Canon PIXMA MP530 All-In-One InkJet Printer
If I want to print it doesnt work, info comes "inner cover is open" what can I do?
  • 375 Answers
Hi Sir, This Inner Cover is actually the plastic door which is usually opened to install or remove the ink cartridges. This door or cover must be open or not properly inserted. Try Re-inserting it and set it Firmly.
Thank you Sir, Have a nice day.
Posted on Sep 25, 2009
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How do I find and remove the printhead?
Here you go:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover. __________________
"If it's really a supercomputer, how come the bullets don't bounce off when I shoot it ?"
Jul 09, 2010 | Canon Office Equipment & Supplies
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
CD printing error 'inner cover is open'
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
I hope it helps!!!
Nov 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Inner cover is open - what inner cover is that referring to
The inner cover is inside and just above where the paper comes out after you make a print or copy.  Reach in and flip the grey bar up to close.
Jul 10, 2008 | Canon MP610 Photo All-In-One Printer
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error is inner cover is open.
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Mar 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
392 people viewed this question
old marine
old marine
