Question about HP Pavilion zd8000 Notebook
HP zd8000 will not boot on battery
Battery Charge light not on/Power management shows 94% charged
  • 375 Answers
If every thing is correct ( the Battery, the AC adapter, etc ) then also the Power light is not turning on, then somewhere the power is not transmitting. The laptop must have a internal connection Breakage. Oh, I saw that you didn't mention AC Adapter. Have you checked it. Also check the the Control Board of the Laptop. Better you give it a Servicing.
Thank you Sir, Have a nice day.
Posted on Sep 25, 2009
I have HP PavilonDv4000.My batery show charge 96% total time remaning 5min.I have new battery first chrge the battery fully.Second,discharge the battery completely.And this battery can't be charge any...
Try another known good working battery and if it doesn't charge and hold the charge properly,
If that doesn't work, try another know good working ac adapter to see if it is actually charging the battery properly.
If that doesn't fix it then you know for sure at that point the motherboard is bad.
May 31, 2010 | HP Pavilion zd8000 Notebook
With the zd8210ca off with power cord plugged into laptop also battery is in laptop. Battery light on front panel is blinking. With laptop booted up battery condition show charging at 0%. Does any one have...
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 14, 2010 | HP Pavilion zd8000 Notebook
I have recently purchased a replacement battery for my HP zd8000 laptop. The problem is that the laptop is calibrated for the old battery and doesn't appear to even want to charge the new one. Any help...
You should first try to recalibrate the notebook and battery using the following steps: (this should be done every three months also as short charges and discharges really mess it up and will give you a false reading)
Step 1 - Disable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list.
Click the Screen Saver tab and then click the Power button.
Under Power schemes, select Always On in the drop down menu.
Under Settings for Always On power scheme, select Never in each of the drop down menus.
Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Step 2 - Fully charge the battery
Connect the AC adapter to the notebook.
Charge the battery until the Windows battery meter is at 100%.
Step 3 - Fully discharge the battery
Remove the AC adapter.
Keep the notebook on until the battery has completely drained and the notebook automatically turns off.
Keep the AC adapter connected to the notebook until the battery has completely charged.
Step 4 - Enable the Windows Power Management
Under Power schemes, select Portable/Laptop in the drop down menu.
Now...
If you go into Control Panel, Power Options, and select the Power Meter tab, what does it say?
If you are still having issues, then do the following and then go back through the recalibration process:
Try going into Control Panel, Administrative Tools, Computer Management then down to devices and there should be an entry for batteries. Select that and right click to select scan for hardware changes.
Jan 04, 2010 | HP Pavilion zd8000 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
May 22, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Nov 28, 2008 | HP Pavilion zd8000 Notebook
Pavilion zd8000 battery will not charge charging indicator light flashes and the mains light remains constant. Renewed battery, tried another mains adaptor still will not charge. Laptop works whilst...
sounds like the battery may be bad. I would first suggest trying a replacement battery and see if it will charge if so problem solved; if however a replacement battery (that is known to be good) still does not work it is possible that your battery charger on your laptop has gone bad, which is possible but very rare.
Aug 01, 2008 | HP Computers & Internet
Boot up problem
Sounds like a hardware problem to me Ken. The indicator lights on the front of the computer don't necessarily mean anything unfortunately. If you have left the system off for 3 hours, (with the AC attached and charging the battery), but it still won't boot from the battery exclusively then I would suggest contacting HP for support. If you still somehow are within the first year of warranty, they will probably send you a new battery, failing that, they would service the notebook and have the motherboard checked to ensure the charging unit is correctly passing current to the battery. I don't believe that accessories are covered by an HP extended warranty so you might be out of luck there, however if you have a store warranty check the guidelines and see what is covered, you might be suprised. I hope this helps.
Nov 28, 2007 | HP Pavilion zd8000 Notebook
Battery is not charging
From HP website- worked immediately for me.
This document pertains to HP Notebook PCs with Windows Vista. Understanding battery charging issues If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues. Uninstalling and reinstalling power management software in Windows Vista In order to correct problems with the battery's power management software, follow the steps below.
  1. Click Start and type device in the search field, then select Device Manager .
  2. Expand the Batteries category.
  3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall . WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
  4. On the Device Manager taskbar, click Scan for hardware changes c01176420.gif . Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Oct 19, 2006 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
