Question about Toshiba Satellite A25-S207 Notebook
A45-S150 Satellite Fan is noisy
I need to replace the primary fan under the motherboard. The fan is making excessive noise and I want to replace it before I hit the road
I have successfully pulled and cleaned the secondary fan and removed the horrible lint in the heat sink and replace memory and drive.
I just don't want to damage the DVD or other components in getting the mother board off to remove the primary fan
    Scholar:
  • 94 Answers
If you don't want to get deep down into the unit, here's a shortcut. You can get a can of compressed air and a household vacuum cleaner.
With the vacuum on and under the circular vents for the primary fan, spray bursts of compressed air into the exit vents. Not just the center but all the way across the vent with the tube as close as possible.
The lint you loosen with the compressed air will be sucked into the vacuum cleaner. That is only a shortcut. The actual full process requires disassembly and cleaning of the thermal compound, and reapplying new thermal compound. You fan should now be able to run at low speed until warm enough to require high speed. If you follow directions well, this should hold you until you can have it properly done.
NOTE: Have the vacuum handy when you first turn on the laptop too, incase lint is blown back into a vane of the fan and not sucked out with the vac. If lint clog is too big to be vacuumed out, it will again lodge into the exit vent, and not provide 100% ventilation but should still be sufficient to idle down the fan speed.
The worse case scenario is that the bearings in the actual fan is wearing out, or the fan is out of balance, and need replacing. (This is also on fans that are brushless)
And yes I am an expert.
Posted on Oct 03, 2009
  • Toshiba Master
  • 4,338 Answers
I could not find the manual for your unit, but on this link it shows step-by-step how to dissasemble an A35 unit. It is very similar to the A45 and it should get you started in the right direction:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Posted on Sep 25, 2009
Need to remove cpu fan
STEP 1Always start laptop dis assembly with removing the battery.
STEP 2
Remove six screws securing the hard drive cover and the heatsink covers.
STEP 3
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
STEP 4
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
STEP 5
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite A45-S151 Cooling Fan Needed
hello,
1. Yes there is one or maybe two fans inside. most likely 1
2. for these instructions you would need a detailed service manual possibly from toshiba.
3. www.google.com
or a local computer repair shop for example.
Jul 12, 2008 | Toshiba Satellite A45-S151 Notebook
Runs very slow... hard disk constantly running
You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
Jan 05, 2010 | Toshiba Satellite A45-S150 Notebook
How do i add more ram
The Toshiba Satellite A45-S150 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A45-S150 can support up to 2 individual RAM modules. Look on bottom of laptop and there will be place to take screw out and you will see the 2 modulars. Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A45-S150.
Nov 28, 2009 | Toshiba Satellite A45-S150 Notebook
Replacing the cooling fan
You can find a guide with pictures there:
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
The guide is for display hinge, but you can follow until step 20 and the rest should be easier!
Aug 25, 2008 | Toshiba Satellite A45-S150 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
My laptop
Dear jennyjoy Please find below the following guide for the A45 laptop. It contains many photos and instructions to take out the whole laptop to pieces http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 17, 2008 | Toshiba Satellite A45-S150 Notebook
Screen problems
Your LCD backlight has burned out, It needs replaced.
Jan 06, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite A25-S207 Notebook Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
