Question about Microsoft Xbox 360 Console
Audio Issue I cannot get audio when I hook up my console with component cable? The visual is there, but no audio? When I hook it up using composit cable, it works perfectly. I do have surround sound, and I have run the Audio through my receiver, but I cannot get any audio?
  • 1 more comment
  • james_curran Sep 25, 2009
    That's a good idea, I tried it, and I still have no audio? Any other suggestions?
    My receiver is currently hooked up to my television and I have working surround sound. I just cannot get any audio from the xbox 360 either on the tv or through the receiver.
    I have even got a new set of component audio/video cables, and the issue remains.
    Oh, and thanks for the help thus far! I really appreciate it even though I haven't solved the problem yet.
    An user who is expert in 3 categories / brands.
  • Microsoft Master
  • 1,001 Answers
Audio Cable for Headphones, iPods, iPhones, iPads, Home,Car Stereos and More High Sound Quality ensure the cleanest sound experience possible Chornic Premium 3 5mm Auxiliary Audio Cable for Headphones iPods iPhones...
Posted on Dec 07, 2016
  • 110 Answers
Component has 3 video cables.... then you have to use the composite Red & White cables as your audio.
so you are using both the component video with the composite audio to achieve this. 5 RCA cables total. you will NOT be using the composite video cable(yellow). But you will use the Red & White for audio...
simple.. good luck
Posted on Sep 25, 2009
  • print-or-die Sep 25, 2009
    Maybe your receiver isn't setup properly. Does it give you sound if you plug it directly into the TV? If it works when you have it in the TV, then you can narrow it down to being your receiver. I can't help any further if your receiver is not setup properly.... just try narrowing it down to the receiver or the xbox.
    good luck.
WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Oct 24, 2017 | iLO Televison & Video
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
How can I connect a WII console to my Champion Plasma CV 142 TV set? Can I connect it with RCA cables?
The 42CVI has both composite and component video in the standard configuration. Either of these should connect to your Wii console. You will get better results if you use component video (3 RCA plugs on each end of the wire for video (Y,Pb,Pr); use a second cable with two RCA plugs on each end for audio.) The Component video is Input-4. The component video cable is usually not provided with the game console. There are 2 composite video inputs on the TV (these use one wire with 3 RCA plugs on each end of the cable for video (yellow) and audio (red and white)).
I hope this helps.
Apr 09, 2011 | Champion 42CVI 42 in. HDTV-Ready Plasma...
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
Connection using Component video No Video
1-Locate the audio/video input jacks AND the component input jacks on the TV.
Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
Look for inputs marked Audio and Video IN.
Do NOT connect the system to anything marked OUT.
2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
I have a samsung led tv and am trying to hook up a wii. The tv does not have component video - only hdmi and usb. How do I hook this up?
I've never heard of a TV not having component cables (the 5 plug cables: red, blue and green video cables, red and white audio cables). I've seen some newer ones without composite (3 cables: yellow video, red and white audio), but never component.
I find is hard to believe it has no component. I looked at some Samsung LED tv's this weekend, and although they lacked composite, they had component. Are you sure you mean component?
The Wii only comes with composite video cables, so you'll need to buy a component video cable for the Wii to hook it up if your TV has no composite inputs.
Component Cables for the Wii
TV's have inputs on the side and rear. If the TV truly has HDMI, USB and nothing else (which I find hard to believe), then you'll need a cheap home theather 5.1 receiver. Ifyou get a cheap one with HDMI out, it should have a few composite inputs on the backside. A cheap sony one can be had for sub $200. If you hook the Wii into the receiver via composite, and the receiver into the TV via HDMI, it will allow you to hook up and play the Wii (and it may upconvert it too, depending on the receiver).
Nov 23, 2009 | Nintendo Wii Console
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Microsoft Xbox 360 Console Logo
132 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
