Question about Magic Chef 5 cu. ft. / 142 liter Chest Freezer CFC0535GRW
Thermostat was sticking so it was replaced. once
Thermostat was sticking and the compressor was no coming on so it was replaced. once it was replaced the compressor runs at 5-7 minute intervals even after reaching it's freezing temperature. What could be causing this problem??
  • mearlj Sep 25, 2009
    the model # for the compressor issue is MCCF5WBX.
Fallowed instructions for start up. twice. let the product set over night and did start up again and fail. the freezer will not chill more than 70. compressor seems to humm but not doing the job.
U might want to replace the start capacitor that gets the compressor to run. If that does not do the trick and you are sure that the compressor is receiving power from the thermostat then you have a compressor problem.
May 26, 2015 | Igloo 6.9 Cu. Ft. Upright Freezer
Replace thermostat compressor
Usually about 500 to 700 $ if it's the compressor the thermostat is way cheaper and there's no compressor thermostat it's one or the other
Dec 08, 2013 | Danby 3.6 cu. ft. / 102 liter Chest...
Compressor will not come on
Check that the freezer has power. After that make sure the thermostat is turned down low. If it still isn't starting, listen for any clicks like its trying to start. If no clicks, replace the start capacitor or thermostat. If there's clicks like its trying to start, try a hard start kit for your freezer, or you might just need a new compressor
Sep 27, 2012 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Maytag Freezer quit working, Light is on, but not cold. Is there anything I can check before calling a service center. The model is MQU2057AEW.
According to your wiring diagram this is about the simplest machine in the world to work on. a369c99.gifMounted on your compressor is a relay. The relay allows all the copper windings in the compressor to be energized momentarily to get the motor in the compressor started, then it drops half the cooper out because that's all that is needed once it is up and running. A thermostat allows current in the circuit till the desired temp is reached. I would check that relay first for signs of wear. They go bad with age. 46684ba.jpg743f4b2.jpgIf the relay is good bypass the thermostat's to see if she comes to life. If she starts working replace the thermostat.
Jul 09, 2010 | Maytag Freezers
The freezer does not keep a constant temperature. The compressor kicks on when the door is closed, then it start defrosting in a day.
Hi there, just happened to see you as I was signing off. I am a refrigeration contractor, so this is something I would do. Mainly commercial units, same concept but different controls is all. Anyway, I will have to ask you questions as we go that you can get back to me on, with my user name. So, how old or new is the unit and when did you notice when this problem started?? We know that the compressor is working, but how good. It comes on and runs, but does it freeze at all before it starts to warm up? Once the compressor comes on when the cold control/thermostat calls for cooling, it should run until it reaches the desired temperature and the compressor will cycle off. Once it has frozen everything and shuts down, it will cycle on and off as needed to maintain this temperature. On a freezer, they have a defrost timer and defrost thermostat located in the system also. What I would like to know is the age and condition over all of the unit, to determine if maybe you have a small freon leak which does happen. Somethings you can check, is to pull it out to get behind it with the thermostat set to its coldest setting. With it unplugged, you should have a lower panel that you can remove to expose the compressor, the condenser coil, and coil motor. See how dirty this coil is as far as lint and dirt that has built up on the front of the coil. Clean it with a stiff bristle brush, not wire. It has to be clean for this motor to pull air back through it to keep the internal head pressures down on the unit. After you get all clean, plug it in as the stat is already to go and see if the compressor and this condenser fan motor comes on and runs. If the motor does not run, this will be your problem as it will be at fault and need replacing. Just spend some time back there and watch to see if the compressor continues to run. The air that you feel this motor pulling through the coil should be very, very, warm! If not, this indicates a loss of freon, and you have a leak. Try and time the compressor to see how long it runs before it shuts off only if the little motor is running, if you are up to it. It is difficult for me to tell you everything to check as we are limited on what you can do. I wish I were there. Anyway, let me know the things I have asked of you to do if you are able. You may just have a faulty thermostat control. We will go there later. Get back to me to let me know what is happening and if it freezes solid before it starts to defrost, and how far it defrosts, like all of the way.
Sincerely,
Shastalaker7
PS, I have to run for an hour or so, but will check as soon as I return. Good Luck
Mar 14, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
The freezer is fully defrosted and will not resume a cold temp.
find thermostat. if open its bad, set to max cold and see if it comes on. if it doesn't gently tap it ,if it comes on its bad and sticking open. replace it. if the compressor doesn't run with stat bypassed the compressor or start components are bad. re[plce start components and if still no run the compressor is bad. usually not worth expense of new parts.if compressor is at fault. good luck.
Dec 06, 2008 | Frigidaire Freezers
Magic Chef 5 cu. ft. / 142 liter Chest Freezer CFC0535GRW Logo
32 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
