Question about Garden
How do you adj walking speed on tb mower 12a186q011112567 speed control handle will not change walking speed
    Problem Solver:
  • 16 Answers
Check the cable for the speed control handle.... at the top of the handle bars, there should be an Adjuster (or possibly half way through the cable) which you can use to remove the "slack" due to the cable stretching. Keep adjusting until speed control is resumed but not to much or the machine may drive all of the time.
Posted on Oct 13, 2009
Can I control speed of self propelled mower ?
most self propelled mowers should have a variable speed. the more you squeeze the handle the faster it will go. it is on a spring lever. as some people cant walk as fast as others. some just kick in at a set speed.
May 20, 2016 | Garden
How do I fix the speed control on an Ariens walk behind lawn mower?
do you mean the throttle cable? as its a push mower im gussing it is. If the mower is relatively new then it will be fitted with an opc (or dead mans handle) in which case there is no need for a throttle control as the engine speed is governed and should only be used at the fixed goverened speed
Apr 08, 2016 | Ariens 21 In Classic Walk Behind Push Lawn...
How can I slow down the speed at wich u can walk with the machine it is a propelled mower. Thanks
If the mower motor speed cannot be controlled, then you cannot control the walking speed.
And most transmissions are directly connected to the motor pulley so that if you slow down down the mower's motor, you also slow down the blade speed and cutting power.
Apr 05, 2015 | Garden
How do adjust for Speed stability on Lawn-Boy mower. It hunts up and down.
Speed control for motor is controlled by an automatic governor, so there isn't any adjustments. Surging is caused by an air leak. Has the air filter been changed? Spray card cleaner around that side of the engine to find the air leak. Does it have a choke adjustment? Make and model would be handy in answering this question!
Oct 18, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
My lawnboy starts but will not shut off. I replaced the coil recently and believe the woring is messed up. Does anyone have the correct wiring diagram for the engine shut off switch?
there should only be one wire to the coil. it plugs into a spade terminal and runs to a kill switch which is usually a piece of metal that comes in contact with a part of the throttle so when you either move the speed control to slow/stop or release the handle the two parts touch and ground out the module
Apr 17, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Nov 17, 2009 | Garden
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
