Question about Samsung Televison & Video
SAMSUNG TV 100HZ HORIZONTAL OUTPUT TRANZISTOR BECOME HOT END FAILS
  • 700 Answers
If this is a normal wear then just replacing the horizontal output with same spec will do the work.
But remember to check first its B+ supply voltage if within spec. Some other reasons why HOT fails are, unregulated voltage supply, shorted flyback. Temperature, if thermal compound dried out. Also on list maybe shorted horizontal deflection coil.
Hope I give you some inputs.
Posted on Sep 25, 2009
My sharp tv 21V-FR70M the flyback will spark when i turn the tv
your FBT insulation has deterioted and needs replacement.eventually the sparking problem may increase.also your HOT(horizontal output transistor)will fail if you do not replace your Fly back transformer.
Mar 08, 2015 | Sharp Televison & Video
Tv problem
It appears that the power supply is starting to fail on your LCD. Many failures like this one are due to bulge or leaky capacitors that overtime become defective.
Jun 26, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Nec pf-68v21 pwr led flashing red green after horizontal output
check the supply at horizontal driver trans former ,if voltage is correct at ho/driver trasistor ...then check allthe fusible resistances from power supply,,,if tv is taking h/oscillation for awhile ,,give more screen control in lot,,, & see for a horizontal line ,,,before tv becomes off,,, if so vertical ic problem...
Mar 16, 2010 | Televison & Video
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like not enough power when power on (maybe sound come from relay)....
Check the PTC parts,the primary AC power supply board.Disconnect the power supply board,measurement the capacitors and power tranzistors,measurement the output voltage(155V),connect on the output on 60W electric bulb,if it light the power source is ok and the problem in the horizontal driver parts(trafo,power tranzistor...).
Sep 27, 2009 | Samsung Televison & Video
When turning the tv on, the blue light comes on but nothing else, no screen, no audio.
The problem in the horizontal driver section.Change the power tranzistor in this section ,the capacitors.
Aug 14, 2009 | Televison & Video
Have sound but no pitcher. Can change channels. Unpluged all cables to tv and get the snow sound but still no pitcher.
HELLO. well from what you say your set dos'e.with sound & no picture.!!! it's in your power supply.!!! the horizontal out put tranzistor
Aug 27, 2008 | Televison & Video
Sony 27s42 broke the horizontal output transistor
Be sure to make sure the connection on the horizontal driver transformer are soldered good. check caps around HOT
May 23, 2008 | Sony KV-27S42 27" TV
Televison & Video Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
