Question about Maytag Dryers
Have to hold button in to run
Maytag mde308dayw have to hold button in to run
    Problem Solver:
  • 16 Answers
The problem is likely with the "run relay" in the electric motor or one of the wires going to the motor connection or a loose connection to the main control switch.
Posted on Oct 03, 2009
  • 832 Answers
You must replace the defective power button, so you can run it normally. This must solve your problem. Just let us know thru
e-mail and vote for the solution.
Posted on Sep 25, 2009
I replaced drum rollers on my Maytag MDE308DAYW electric dryer, but am having trouble getting the blower cover aligned when replacing the bulkhead - any suggestions? Thanks.
Dip the TOP into the Opening and then bring the Bottom or Open the Door and hold the Drum UP while installing works for me all the time...
Jan 03, 2015 | Maytag Dryers
My maytage dryer mde308dayw drys the clothes, but it takes a longtime. The dryer heats, but water builds up around the inside of the door of the dryer.
You will need to clean the vent system on your dryer. Lint buildup restricts the airflow and will keep the clothes from drying.
Oct 17, 2011 | Maytag MDE308DAYW Electric Dryer
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer model MDE308DAYW will not start. Why?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
Maytage MDE3080DAYW
Hi, it sounds like you have a bad motor. You can try and open the door, hold the door button while having someone push the start button. Try turning the drum with your hand while these buttons are pushed and see if the dryer starts. It sounds like the start winding has gone bad.
If the drum will not turn, remove the front panel of the dryer and see if something has gotten into the blower wheel to stop it.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 13, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Jan 16, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
