Question about Canon EOS Elan 7e 35mm SLR Camera
When putting in the battery it won't wind the film?
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jul 18, 2016
When I wind on the film and press the button nothing happens
Many 35mm cameras will not work without batteries. Also clean the battery cap in case your batteries leaked.
Oct 16, 2014 | Photography
My canon eos 1000 keeps on rewinding the film into the cannister when i put a new film in
The XS normally winds the film completely out of the cassette and then rewinds it back into the cassette as you take pictures
Feb 08, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
Where and how do you insert film on a minolta vectis 2000 camera
Essentially, you probably don't as APS film is no longer made and is getting difficult to get processed if you do get some old stock.
But like on all APS cameras, there's a lock on one end of the camera and usually you turn it to open a small door on the bottom of the camera. The APS film cassette gets pushed into the compartment and when you close the door and the camera *should* wind the film ready for shooting and lock the door so that you cannot open it until the film is rewound. The cameras are entirely battery dependent and many used CR2 lithium batteries which are disproportionately expensive and hard to find except from online suppliers.
Unfortunately APS was a badly engineered system from the start, so the cameras didn't tend to last long before suffering major faults. You may wish to bear that fact in mind as those faults won't show until you load a film and any film you do find will likely cost more than you can buy another APS camera for. They're widely available for free or for about a £ or two from almost any charity shop (not from the one I work in though as I always put them straight into the recycling bin as they're a liability).
Aug 14, 2011 | Minolta Vectis 2000 APS APS Point and...
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
I put the film in the camera, turned on the camera, and the camera will not wind the film. The screen flashes "Err"...I don't know how to solve this.
Just do reset first by taking the battery for 3 hours,if reset button is not available. Then after 3 hours put it back again and see what is the result. If reset does not fix then camera has an internal problem. There are two common problem if the film will not wind . First is the gear is damaged already that can't drive the film and secondly the motor is faulty already.
Good luck:
Don't forget to rate:
Jul 08, 2009 | Nikon N75 QD 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Canon EOS Elan 7e 35mm SLR Camera Logo
70 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
