Question about Kenmore Ovens
Wall oven not working at all
I have a Kenmore Pilot Free Ignition wall oven, with broiler underneath. It won't turn on. Nothing. I don't know the model number or the age, approx 15 years. We bought the house 12 years ago.
Mine is broken too. exact same problem. same oven. email me if you fixed yours, please!!! quinnalisen@comcast.net
Posted on Apr 06, 2010
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
I have a propane Jenn Air gas wall oven. The broiler works fine, the bottom log will not light because it isn't getting gas. The light to ignite the gas is working fine. What do I do? I do not have the...
Hi I think that the Thermo-couple is bad That is the part that senses the flame or electric heat coil-heater warming up to ignite the flame for pilot light. there is a rod that is next to the electric coil which senses the heat coming from the coil. If that isn't working properly the pilot wont light and the log won't lite because the gas valve won't turn on for safety factors. The part is nit too hard to replace but you need to lay on the floor to get at it.
Sometimes the lower shield or bottom lifts up and removes
to service it . the thing is small about 1 in long with a copper tube, or steel braided jacket around the wire. the coil is maybe 6-10" long when rolled out. But don;t roll it out or bend a sharpkink in the thin copper tube because it will be ruined. The part doesn't cost much $10.00 -30.00. you may need some screwdrivers and 3/8 "or 7/16" open end wrench and maybe a 1/4 in. nut driver pliers..
Good luck, Bill
Jan 07, 2018 | Jenn-Air 30 in. Pro-Style Electric Single...
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
We have a kenmore wall oven and we need to know how to relight it. it is g a gas oven.
your oven lest its very,very old dose not have a standing pilot.it lites by demand when you turn on
Jan 01, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
395 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
