Question about Samsung Digimax S730 Digital Camera
Wont turn on
Put new hybrid 2100 ma rechargeable batteries in it it turns on but beeps three times then shuts off
  • Kevin Lockhart Dec 17, 2007
    the battery meter was full from whyat i can see
  • Anonymous Dec 18, 2007
    my camera turns on and beeps three times and has a full battery meter. I changed my batteries like four different times and the bugger still wont come on.. Do i need some specific batteries or what?
    Problem Solver:
  • 5 Answers
Are you sure that your batteries were fully charged? I have the same issue when using shop bought aa batteries - or they don't last very long at all.
That 3 beeps and turning off is what should happen along with a "battery low" error message on the screen from experience.
When I bought the recommended charger and two batteries from Amazon - they lasted a lot longer. Search the website for the charger battery code suggested in the instructions.
Posted on Dec 17, 2007
Honda civic hybrid
A hybrid vehicle is a vehicle that uses two or more distinct power sources to move the vehicle.[1] The term most commonly refers to hybrid electric vehicles (HEVs), which combine an internal combustion engine and one or more electric motors.
Jul 27, 2008 | 2005 Honda Accord
Camera not working - S85 Digital Samsung Camera
If you've had the rechargeable batteries for a long time, they can wear out. I would try getting some new rechargeable batteries or try some lithium batteries in your camera. They're a little more expensive but they're the best for digital devices and they last a little longer.
Jun 16, 2008 | Cameras
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
Camera not working
Usually when the camera beeps 3 times. It means the battery is low. Then it turns right off. What kind of batteries are you using for your camera?
Dec 27, 2007 | Samsung Digimax S630 Digital Camera
Digital Camera
make sure that the rechargable batteries mAh value is at least 1800, personally i recomend 2100
Dec 23, 2007 | Cameras
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Canon A95 "Change Batteries" problem!
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
Aug 06, 2017 | Canon PowerShot A95 Digital Camera
Wont stay on
You probably don't have the batteries fully charged up. Also you will need to change battery type from alkaline to metal hydride in the "wrench2"(the last icon on the menu) menu. You did get metal hydride rechargeable batteries??? If you got nickel-cadmium rechargeables that might also be your problem with your camera as they don't have enough power.
Aug 28, 2007 | Samsung Digimax S630 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S730 Digital Camera Logo
283 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
