Question about HP Pavilion dv9000z Notebook
No power from cord to computer
HP Pavillion and died because no power was recharging. Noticed that the female end that plugs into lap top was extremenly hot. Have tried several times since and it is dead. It is really a hp pavillion dv9700 notebook laptop
    President:
  • 942 Answers
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Posted on Sep 25, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
The last time I used my Compaq Presario v2000 I had it on battery power. The battery died and now that I am trying to use it I have the power adapter plugged into it and I get nothing when I hit the power...
This problem is either due to your power adapter, wall plug or the back of your lap top where the power adapter goes into. My guess would be the power adapter, they are infamous for going bad. Try wiggling the cord that connects to the power brick (black box) from your lap top.
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
No power on presario hp v2000
maybe this document will help you:
h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Apr 10, 2009 | HP Compaq Presario V2000 Notebook
Computer can't find printer
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
Nov 19, 2008 | HP Laserjet 2605 Printer
Dont know how to turn on
The monitor has and adapter type power cord that plugs into the computer end of the VGA cable. Look for a small round hole at the PC end of the cable.
Jun 08, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Pavilion dv9000z Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
