The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and reset
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Posted on Sep 25, 2009
When startin up it would show a message that air flow was blocked replaced the Thermal Sensor, now the timer lite blinks green then the lamp lite blinks yellow and the green light go out. I hav a new lamp...
After the TV has shut down, without pressing reset: press and hold both the Device (Input) and Menu buttons on the front panel until the green light starts flashing. It will flash a two digit code: 3-4, 3-8, 5-7, etc. You may have to let the TV shut down a couple of times (without pressing reset) before it will give the code.
Please post the code to help me determine the section of the TV that has failed and what it will take to repair it. It may be a good idea to repeat the test a few times to make sure the TV is giving the correct code.
Let me know.so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 21, 2011 | Mitsubishi WD-Y65 65" HDTV
TV doen't turn on
Its time to buy a new one, buddy.
Oct 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
Dec 14, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
