Question about Gateway Computers & Internet
Hello, \r\nWe are having issues with our Gateway
Hello, We are having issues with our Gateway ML6714 laptop. It wont charge for some reason. We got a new charge adaptor and battery but that only lasted for about an hour. Is is the power jack...does it need to be replaced?
  • compies Sep 25, 2009
    I have purchased a new battery. I've looked online for people who've had the same problem, which I think is the power jack. Whatever the case, why would it not power up at all? possible short in the adapter?
    President:
  • 2,923 Answers
Since you've got a new power adapter and you tried another battery as well, most likely, the power jack is the problem.
You may verify it by doing the following:
1. Remove the battery from the laptop.
2. Plug the power adapter slowly and check if the power jack is wiggling.
3. Turn on the laptop.
If the laptop works intermittently (turning ON/OFF), then it's the power jack problem.
But if same problem exists after replacing the power jack, then the problem has something to do with the circuit board of the laptop.
I'm hoping that the laptop is still under the warranty so that you could have a free service.
Have a great day!
Posted on Sep 25, 2009
  • 4,281 Answers
It is not power jack issue if your laptop has no issue with direct supply it is issue with your battery your battery need replaced then it works fine.
Let me know if you need more assistanse.
Thanks.
I have teshiba L650 I PUT NEW BATTERY IN IT NWE BATTERY CHARGER CORD AND COMPUTER COMES ON BUT FOR SOME REASON BATTERY WILL NOT CHARGE UP EVEN PLUG IN TO ELECTRIC SOCKET
Try removing the battery and use your charger only in powering up your computer to check if your charger still works. If it doesn't power your computer then you need to replace the charger.
David
Mar 20, 2013 | Acer Aspire 3000 Notebook
Computer wont turn on
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 25, 2011 | Gateway Solo 1450 Notebook
My six month old, LT gateway netbook wont charge...50% percent HELP!!!!!!!!!!!!
sounds like you'll need to get in touch with gateway for warranty repairs/replacement, though, you may try to remove and reconnect the battery, check for BIOS updates from gateway that may include fixes on battery charging , and test if the battery will have same issue when connected to another system, if available. Try to also leave the netbook connected to the adapter/charger for a few hours while switched off as it can help the battery to charge faster.
Sep 04, 2010 | Gateway LT2021u Netbook
Got a gateway ml6714 that runs hot then freezes up. i think the processor fan is failing. what can i do?
A search for that part showed a lot out of stock. But here's one on eBay. http://cgi.ebay.com/Gateway-M675-Dual-Heatsink-Cooling-Fan-8008625-/230467425374 If you think it is bad there is no other way to find out unless you replace it and see.
May 07, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
you can take the laptop to a laptop shop & have them resolder the power plug to the mother board or purchase a new motherboard.
Jan 16, 2009 | Computers & Internet
How to repair a gateway ml6714 notebook, the power plug in shorts when power coord is plugged in
IF YOU ARE NOT SOUND ON TECHNICAL GROUND ITS BETTER TO BE DONE BY SOME TECHNICIAN
Oct 26, 2008 | Computers & Internet
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Computers & Internet Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
