Question about Uniden DCT646-2 Cordless Phone
I have a Uniden Dct 958 AND i PRESSED SOMETHING THAT SAYS PHONE IS OUT OF RANGE; IN FACT IT IS SITTING ON THE BASE BUT i CAN'T GET A DIAL TONE OR GET IT TO WORK; ANY HELP WOULD BE APPRECIATED.. THANKS tHIS PHONE WAS BOUGHT AND IS USED IN iSRAEL AND THE INSTRUCTIONS ARE IN heBREW; NOT A GREAT HELP.
I HAVE SIMILAR PROBLEM
Posted on Oct 04, 2009
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
Why will my uniden phones not dial out, all units will not dial out. Phone jack works, but when I try to dial, with each digit pressed I only get a dial tone. Phone will receive calls, but I cannot dial...
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires.
This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular socket you are plugging
the base ('main unit') into.
Feb 18, 2015 | Uniden Cordless Phone
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
One handset on my uniden dxa13288-2 does not work. The battery is charged and good (swapped with other unit). When placed in masterbase, base led flashes, indicating good data marriage on both. The good...
The handset for this unit registers automatically to the base. The main base sync with the handset but it does not respond. The handset that is not responding has a problem and should to be replaced. You can pick one up on eBay for a few bucks.
Jun 02, 2017 | Uniden 2.4GHz Digital Answering System...
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Uniden 2.4ghz digital house phone
There is a "Tone / Pulse" switch or program setting you want set to "Tone". It would be part of the base unit and not an option on the cordless handsets.
Jun 23, 2007 | Uniden DCT-7488-2HS Digital Phone
No dial tone...but can hear the tv
move the Base unit away from the TV. Check if ADSL filter in use may need to replace one or all ADSL filters
2.4 GHZ hmmm do you have 802.11 BNG WI FI in use with any of your computers ???
2.4 Ghz is a problem as computer WI FI uses this frequency as well !
check the line cord is plugged in to the base unit
Check base has power
May 24, 2017 | Uniden DCX770 for DMX700, DCT600 Cordless...
Uniden DCT646-2 Cordless Phone Logo
199 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
