Question about Craftsman Garden
Push mower blows gas out muffler - Craftsman Garden
  • Craftsman Master
  • 7,482 Answers
Your needle valve under the float jet in the carb is stuck.
You need to pull the carb apart and clean the needle valve under the float.
With it in the stuck open position, your gas will flow to the carb air intake and flow out onto the deck of the mower.
Posted on Sep 25, 2009
4 Suggested Answers
  • 59 Answers
SOURCE: My grandson was mowing with the 22 inch push mower
first, be sure someone has not over filled the oil. if thats ok, sounds like the piston rings are shot.
Posted on Sep 23, 2010
cq92
  • 184 Answers
SOURCE: push mower won't start. Oil coming out of muffler
Your motor is pooched. Oil is not supposed to come out the exhaust. It indicates a worn out motor or something broken inside like a piston or compression rings. Or possibly someone has put half a gallon of oil in it instead of half a quart and it's well overfilled?
Posted on Aug 31, 2009
vincob
  • 718 Answers
SOURCE: my lawn boy 6.5hp mower isblowing fuel out of the muffler
Maybe it's a stuck float valve or a bad float. Had a similar problem on a TORO rider but that turned out to have a pin hole in the brass float, it filled up with gas and let just about the hole tank through the muffler. I changed the brass float and still running to this day! Note: your float may not be brass if it is a newer machine it will be plastic.
Posted on Oct 01, 2009
Gas pours out of carb and muffler
float could be ok but the needle and seat or bad replace them
Aug 16, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
I have recently bought a poluan pro mower. It has been spitting oil in filter and blowing out white smoke from muffler.
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
Sep 22, 2013 | Poulan "Poulan" Push Mower
Gas is flooding out through the muffler in my push mower
sounds like the needle valve in the carb is not seating replace them and the oil
Jul 05, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Turned mower on its side and changed the blade and now the pull rope is very hard to pull..its almost like the motor is locked up..I checked the shut off linkage cable,removed the spark plug, removed the...
Your piston cylinder is partially full of oil and/or gas. Take the spark plug out and pull the rope four or five times to blow everything out of the cylinder. If it's still hard to pull over with the plug out check the oil level in the crank case to see if it filled with gas while the mower was on its side. Make sure the plug is dry and clean and reinstall it. When it starts it's going to smoke a lot until it cleans out the cylinder.
Sep 15, 2010 | Poulan "Poulan" Push Mower
My mower will start but not run. Oil and gas is leaking from exhuast and filter. What could be wrong?
if the filter is a sponge filter then it's suppose to have oil in it(helps trap dirt) and if your getting gas out of the muffler then the engine is flooding when you try to start it..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
My lawn boy 6.5hp mower isblowing fuel out of the muffler
Oct 01, 2009 | Garden
Blue/white smoke from muffler, but when muffler is removed smoke disappears
Obviously it has had oil or similar inside it at one time or another. Have you given it enough running time to burn all that out? How old is lawnmower & was any work done recently to it?
Aug 03, 2009 | Briggs & Stratton Garden
Lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Apr 05, 2009 | Garden
Garden Logo
466 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
