Question about Air Tools & Compressors
When the moter warms up it dies /already changed spark plug and cleaned carb
    President:
  • 1,167 Answers
Have you tried a different heat range eg 10,<hot-cold>1
Posted on Sep 25, 2009
When Moter gets hot it won't idle then stalls when open throttle
Hello Ian. I would check the big three. Compression, spark and fuel. Once engine warms up and dies I would immediately check compression and compare it to stock spec. If that is good I would hook up an inline spark tester and run unit , while observing spark tester to see if you lose spark. Then I would check for fuel obstructions, lines, carb, etc. This should greatly narrow your problem. If you have questions, just post in this thread and I will get back to you. Good luck.
Feb 27, 2014 | 2005 Gas Gas EC 450 FSE
Engine (Quad-4) turns over,starts momentarily,then quits; this will happen over and over, but it will not continue to run???
Check if all of the plugs are getting spark. You can do that by pulling the high tension wire at the spark plug end and over the engine check if all are getting the blue arc. Check if the fuel filter needs changing. The fuel supply may also not be consistent, check during start up if fuel is being supplied to the lines via the filter or the hose to the engine also after the engine dies. Fuel may just be only at the start up and when idling supply is low or gone.
I am unsure if your year has the fuel pump already, it may be the fuel pump relay or the fuel pump has gone bad.
Try cleaning the intake with carb cleaners just to rule out dirt in the sensors and the manifold. Check for leaks in the vacuum hoses and air duct from the filter to the intake. It may also be the IAC valve or the EGR for the EFI variants, IAC especially if the idling after start up and before dying is rough. It may need cleaning or replacing.
If you still have the carb or it was converted to carb you may need to adjust the fuel and air by moving screws by quarter turns on the carb and taking note of the movements. It could also be the jets for the fuel which may need cleaning. Carb cleaner would do the job but for tough dirt you may have to remove the carb and clean the internals. During cleaning you may inspect the valves and the parts for wear.
May 27, 2011 | Pontiac Grand Am Cars & Trucks
Starts fine but dies when set to run.
You either have a air leak in a fuel line, carb jets are plugged, or carb seals went bad. They sell a rebuild kit for your carb, 10-15 dollars. I would start by removing carb spraying it with carb cleaner and blowing it out with a air gun, put it back on and see if this worked. If not I would replace fuel lines and rebuild carb.
Jul 25, 2010 | Poulan Garden
LINCOLN 225 WELDER OLDER MODEL ABOUT 1985. 16HPENGINE. AFTER GETTING GOOD AND WARMED UP IT STARTS MISSING SOMETIMES BACK FIRES EVENTUALLY DIES. REPLACED COIL REBUILT CARB ,NEW FUEL FILTER AND LINES....
check plug and wire. you will want to do a compression test while you have the spark plug out and make sure you have no blow-by that will cause it to miss.
Oct 08, 2009 | Welding Tools
Changed Spark Plugs & Air Cleaner on 2003 Rebel CMX now when it warms up it idles way down & dies
Adjust and if needed, clean the carb. If fuel injected, turn up idle or let computer adjust itself which it will eventually do through time.
Sep 09, 2009 | 2003 Honda CMX 250 Rebel
The engine will not throttle up and it runs rough. Dies at an idle. Whats wrong Already changed spark plug and put new gas in
Sounds like the carb is needing a good cleaning. Get a spray can of Berryman's Carb spray cleaner.
Take the carb off and clean the carb bowl (if it's a 4 stroke motor) and remove the gas line, and with the spray tube nozzle, spray out as much of the jets, orifices, etc in your carb, let it dry out and reassemble.
Also, take the air filter/cleaner off and make sure it's clean. If it's full of dust and dirt, it will choke the carb off and it'll die at idle.
You can test this by removing the air filter element and starting the tiller. Alot of the small engines have a low oil sensing device and will shut down the engine if there is insufficient oil in the crankcase... be sure to check that too.
Let me know how it goes.
K
Aug 15, 2009 | Mantis Garden
1975 75 horse johnson stinger wont idle in gear or run in gear
sounds like the reverse sensor switch is stuck in lock mode
check the switch
Aug 03, 2009 | Boating
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Bike runs at Idle but dies when given gas
have you changed the fuel filter? you are not getting enough gas, are jets squeaky clean? there is a good fuel system cleaner in the USA called Berrymans B12. put some in the tank warm up bike then let it stand overnight and see what happens. if still no luck repeat process. if you still have same problem then get new fuel filter
good luck
Apr 02, 2009 | 2001 Yamaha TW 200
Air Tools & Compressors Logo
27 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
