Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Machine doesn't drain HNWF3135
Machine doesn't drain, i've emptied the front filter but nothing. There is no draining noise as usual ?
  • Hoover Master
  • 7,482 Answers
Check your belt in the rear of the machine, it has either slipped off, or is broken. It must go around the pulley of the drain pump in order to pump the liquid out of the washer.
Posted on Sep 25, 2009
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Nextra HNWF 3135 doesn't work hole cycle, after washing stops, doesn't rinse or spin, these steps I must set up manually, because it doesn't do. I've tried to do with different programs...
Ok hot water being still there and not draining is a clog in your drain line or pump issue. I have not yet brought up the schematic to your unit but on some units there is a clean out filter located down the bottom in which you would clean out the filter careful water does come out when you unscrew the filter on other models that do not have the filter door you would remove the lower panel on the front which would give you access to the pump and the drain lines as well even though if you do find items in the filter you still need to disconnect the drain lines going to and leaving from the pump to assure that nothing is blocking or clogging the flow of water. Im glad you replyed about the hot water still being on the inside definite clog in the drain line or pump or filter issue. If you have any further questions message me back. I await your reply Thanks
Rick
Sep 25, 2011 | Hoover Nextra HNWF 3135 Front Load...
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
E20 error on Kenmore front loader. The water is
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
129 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
