Question about Samsung Digimax S600 Digital Camera
My camera was working fine now it will not focus it is a samsung s 600 has anyone any idears its driving me mad thank you
Quantaray 600-1000mm Telephoto Zoom Lens FOR NIKON work with D3100 in all modes?
The lens is a manual focus lens. It doesn't matter which mode you have the camera in, you'll still have to focus it yourself.
Nov 16, 2012 | Quantaray 600-1000mm Zoom Lens
Samsung ES-17 power problem
This could be a battery problem, as the camera draws more power when switched on, to work the lens and focusing. Try changing the batteries. If its still a problem, you have a camera fault.
Jul 17, 2010 | Samsung L200 Digital Camera
I have tried to buy a new battery to see if that was the problem - = but no. I can tape for aproxemately 1-2 min then it says d and then ejeckt? anyone have an idear - or should I just buy anew one?
Try buying a NEW tape designed for your camera. Check your manual for correct one. Should be available at Walmart.
Next:
Use you power adaptor to test. If it works with that I'd suspect a battery problem.
Dec 28, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Blurred Taking Pictures, But not all the time???
lens misallignment due to worn out gears on focus adjustment (zoom in/out), needs repair but could be expensive and not reliable enough.
May 20, 2009 | Casio Exilim EXZ75 Digital Camera
Auto focus quit working
Did it get dropped when the camera was open? If so it could have made the lens pop out more on one side. I'm not sure how to really explain it. When you open the camera, the thing that comes out might be off track I guess you could say. What setting are you using it on?
Dec 21, 2008 | Samsung Digimax S730 Digital Camera
Samsung slik j 600 problem
I am not getting the samsung slik mobile software for windows vista
Nov 03, 2008 | Samsung SGH-J600 Cellular Phone
Error code S0042, DIMAGE G600
I had this problem with my 600. I noticed that the end, center, part of the focusing mechanism was slightly out of alignment. (The part that usually sticks out furthest.) Once I straightened that piece, it was able to retract and the camera could be closed. Look at the focusing mechanism from all sides to make sure it is straight. The part was very slightly off, but enough to cause the error. My camera has been working fine since.
Aug 14, 2007 | Konica Minolta DiMAGE G600 Digital Camera
Samsung Digimax S600 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
