Question about Hotpoint WMA48 Front Load Washer
Washing Machine - Hotpoint
Hi, as soon as I switch on my washing machine it blows the electricity downsatirs?
  • 3 Answers
Check for short-circuit in the motor or in your main water heater.
i hope you find your solution here.
Posted on Dec 16, 2007
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Wmf540 hotpoint washing machine
This video will show you how to open your Wmf540 hotpoint washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 08, 2013 | Hotpoint Washing Machines
Its showing F 05 and all lights are flashing its a hotpoint model wmf740k
The error that you get means that the pressure switch is jammed on full capacity. Please try using with less loads and sees if it repeats. If the message still remains ten try replacing the pressure switch.
You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Please isolate the machine first and the switch will need removing from the machine.
Thanks,
E-ware
Jul 27, 2011 | Hotpoint Washing Machines
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarias wd 420 hotpoint
sound like motors or heaters have a short good luck.
Sep 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Sep 03, 2009 | Washing Machines
Door lock light flashing
WASHDOCTOR
Rank:guru_s.gif Guru
Rating: 87%, 146 votes
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Apr 29, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Feb 27, 2008 | Washing Machines
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint WMA48 Front Load Washer Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
