Question about Samsung SCH-u340 Cellular Phone
The alarm clock won't set. It works for a while then mysteriously turns off and won't save settings the next time I go to set it. Brought it in to Verizon tech who cleared something and it worked for a couple more months but now the same problem persists. what did he do to reset the alarm?
SOURCE: issues with samsung u340
on the options menu for the alarms instead of clicking to reset a single alarm you must reset all alarms at once.. worked on mine anyway.. wish you luck
Posted on Nov 19, 2007
Bajanguru
  • 7752 Answers
SOURCE: Alarm clock won't ring - Verizon v3m
what you can do is go to ringtone settings and assign a specific tone to it....and then test it
Posted on Jun 02, 2008
vulcanmaster
SOURCE: alarm clock
I had the same problem. Finally in frustration I did the following. Press MENU, then 6, then 4, then Options, then 3 (Reset All). This apparently clears all the alarm memory and my alarm settings would then save properly. I hope this helps you!
Posted on Dec 01, 2008
phoenix chi
  • 389 Answers
SOURCE: the alarm clock stopped working
try resettign the phone but it will delete evrything on it. since you already tried cheking it. go to menu-setings-reset settings-phone settings.
Posted on Jul 03, 2009
lmlage86
  • 34 Answers
SOURCE: Does not save alarms
Go to Menu, Tools, Update software. The phone has a sotware update meant to address this issue.
Posted on Nov 18, 2009
Lost the manual for Bauhn Radio Alarm clock from Aldi item code 50363 Need to set clock for Daylight Savings Time
Set the alarm clock
Press the "Alarm 1" (
1.
The display will begin flashing.
Press the alarm button one time to choose radio or press the button a
2.
second time to choose the buzzer to wake you up. Press the button a third time to turn the alarm off
Nov 06, 2017 | Audio Players & Recorders
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
Have a bluehat time space projection alarm clock and the alarm won't turn off. Always goes to a snooze mode. Need help making it turn off. Instruction Manuel offers no help.
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
Jan 19, 2012 | Toys
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
Need help setting the alarm on my iphone ka08
Ok, go to the clock face on your App screen, then ensure the alarm clock at the bottom, second from left is highlighted. Tap edit, top left, tap which alarm you want to edit just to the right of the time and then use the wheel at the bottom to set your time by dragging up and down. You have various other options to play with but you can hit save, top right and thats your alarm set. Confirm this by seeing a small clock face at the top left of the screen next to the battery.
Hope this helps and please vote if so.
Thanks
Jim
Jan 20, 2010 | Apple iPhone 3G
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Lost the manual for my nexplay alarm clock/ipod dock
Setting the Clock:
1. Press the SET Button 3 times until all digits for the main clock are flashing.
2. Press Skip forward and back to change the hour and Volume up and down to change the minutes.
3. Press the set button once to save.
Sep 11, 2009 | Starlite Next Play Clock Radio with iPod...
Setting my clock,model88000/86601
For any Equity clock, press and hold down the Alarm Set button. First the year will flash, if you don't care about the year, press the Alarm Set button again, if you do care about the year, press the arrow button (it could be an UP/DOWN arrow or a side arrow which is usually used to change from Centrigrade to Fahrenheit).
Basically, you begin by pressing and holding the Alarm Set button, then you use the arrow buttons, then again press Alarm Set to go to the next thing you want to set. If you wait too long, it will not set it, so begin again. I do this all the time, esp when DST occurs as the clock, when manufactured did not have the rules for the new DST time.
Jan 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Samsung SCH-u340 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
