Question about Corel DRAW Graphics Suite 12
The letters appearing on the screen are not the ones I typed. I've tried reinstalling. If I open an old file I can overtype successfully once then it starts with the different letters.
  • pylypiw Sep 26, 2009
    I've done that twice and also tried the reset by pressing F8. No change
    I have uninstalled and reinstalled twice and also tried the F8 reset thing.
  • 284 Answers
There is a good discussion here where they talk about a similar problem. Unfortuanately they did not post an answer but it may give you some ideas on where to look on your system A Google search didn't turn up much for me.
It may not be relevant to you if you are using a non localized English version of windows. i.e. The cause may be to do with using different languages on your pc.
I also saw stuff where you can create your own custom fonts. I don't suppose you have been experimenting in that area. If you do an uninstall and reinstall you should make sure that there are no files left over. Normally uninstalling will not delete any files that the installer did not originally create. So the program may just reuse the corrupted custom fonts.
The other thing is if this is a legitament current version of the software you should be able to get help direct from Corel.
Does it always come up with the same incorrect pattern or is it simply all over the place?
Posted on Sep 26, 2009
  • 10,515 Answers
Try to Uninstall and Reinstall the software.
Let me know, if the problem still persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
How do i reset my garmin colorado 300
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:\Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
> cd c:\Garmin
At the next command prompt type the following command without hitting enter:
> Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
May 07, 2011 | Garmin Colorado 300 Handheld GPS Receiver
What is the work of insert key of keyboard.
The insert key is used to toggle between overtype mode and insert mode while typing.
In overtype mode, any letters typed will replace those infront of the cursor.
In insert mode, any letters typed will be inserted where the cursor is. (Useful for if you miss a letter or word out)
Dec 17, 2010 | Microsoft DA900013 Keyboard
When typing an email in Mail on aluminium Macbook in Mail errors
Hi Sherry, When did this start happening and how old is the MacBook?
Go to software update (apple menu) and see if there is a firmware update available for your mac. I have a recollection of an update to fix an oversensitive scratchpad and/or keyboard issue (but I might be wrong).
Does it only happen with mail?
Jul 28, 2009 | Apple 13 MacBook Notebook Computer ...
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
How do you get a computer out of preparing to run system set up? it stays stuck there
Before you start looking at reinstalling Windows you need to back up your important data – just in case anything goes horribly wrong.
Reinstallation loadTOCNode(1, 'summary');
Reinstalling from Windows
If you are able to get into Windows then you should start off by putting your Windows CD into your CD-ROM drive. Close down the automatic pop-up screen that appears when the disk autoruns and then open Windows Explorer. Point explorer at your CD-ROM drive and in the root of the drive you will find a file called SETUP.EXE. Double-clicking this file will start the installation of Windows. Skip to ‘The reinstallation procedure’, below.
Reinstalling from DOS
If you can’t get into Windows then you are going to need to use your boot disk to see your CD-ROM drive. You should have a boot disk already – if not then you should elsewhere in this article for information on creating one. Once you have this disk you should boot your computer with it in your floppy drive and restart your PC. Once the disk has booted, put the Windows CD in the CD-ROM drive, switch to the relevant drive (by typing the letter of the drive followed by a colon, such as D: or E:, and pressing [Return]) and then type SETUP.EXE and hit [Return]. Windows will now start reinstalling itself.
How to create a boot disk if you can’t get into Windows
Boot into DOS (press [F8] on startup to bring up the boot menu). Put a floppy in your drive and type format a: /s. This will create a bootable floppy disk. The next stage is the crunch point – you need to find the system-configuration file for your CD-ROM drive and copy it to your floppy disk.
Next you need to copy the Microsoft CD extension on to the floppy disk. Enter COPY C:\WINDOWS\ COMMAND\MSCDEX.EXE A: and hit [Return]. If this file isn’t there, it’s corrupted, so you need to find it. To do this in DOS you should type DIR /S MSCDEX.EXE, to search your drive. Once you find it, copy it on to your boot disk.
Next, make your floppy recognise the CD drive when it boots by creating CONFIG.SYS and AUTOEXEC.BAT. In DOS type A: to take you to the floppy drive. Next, type EDIT CONFIG.SYS. Type in device=< 'drivername'>.sys /D:mscd001, where 'driver name' is the name of the .SYS file from step two.
Save your CONFIG.SYS file. Next we need to create the AUTOEXEC.BAT file. Create that file by typing EDIT AUTOEXEC.BAT. Once this file comes up you should type MSCDEX.EXE /d:mscd001. Save the changes out to your disk.
uparrow.gif loadTOCNode(1, 'summary');
How to create partitions in DOS
FDISK is a powerful utility, and relatively straightforward to use. Remember that you’ll lose all your data as soon as you create a new set of partitions, and you’re away…
Boot from your floppy disk and make sure you can see your CD-ROM drive, as you are about to leave your old setup. Once happy, type FDISK to start Microsoft’s partitioning program.
Select option 3 to delete partitions and delete everything. Once you’ve done that you can create your partitions again. Select option 1 and then 1 again to create the primary partition to the size you specify.
The next step is to create your extended partition. Select option 1 followed by option 2 to start creating this second area. When prompted you should make the extended partition use all the space left.
The last step doesn’t actually create any logical partitions – you have to create these yourself in the extended partition. FDISK will automatically prompt you for the first one, just set it as big as you want.
Finally you should check that all the partitions are set up as you want them by selecting option 4 from the main menu again. Once happy with your setup you need to re-boot and then format your drives.
Reinstalling loadTOCNode(1, 'summary');
What you need
- 45 minutes of free time.
- Your Windows Product Key.
- Another blank floppy disk.
Don’t forget!
First, insert your boot disk, switch on and ensure your PC is set up to boot from the floppy drive – if it isn’t, enter your BIOS, select your floppy drive as the first bootable drive, and save your changes and exit. You should be presented with a menu. Choose the option to start with CD-ROM support.
Next you choose your set-up options. ‘Typical’ is the normal choice, ‘Portable’ is for installing Windows on a laptop, ‘Compact’ saves disk space by not installing optional components and ‘Custom’ is ideally for advanced users. We’d recommend you choose Typical.
During the next stage of the installation Windows installs software drivers for any plug-and-play devices you have attached to your system. After that, various Control-Panel settings are decided. You need to choose your geographical location in the Date and Time Properties dialog box.
Next you need to reinstall your monitor drivers. The Add New Hardware wizard will appear and try to locate drivers for your monitor. If you’ve got them on CD or floppy then put the disk in now and select Let Windows Search for Drivers. If you haven’t got any handy then you can choose Display a list of drivers in a specific location. Choose the default plug-and-play monitor.
The default monitor will get you into Windows, but limit you to 640x480 screen size with 16 colours. Once you’ve installed your monitor driver, install your graphics-card drivers. That’s it, Windows is reinstalled! Now it’s time to turn to move on into the post-install phase…
Post install loadTOCNode(1, 'summary');
Finally, your installation is complete and you’ve got a working version of Windows. A quick look at your Windows folder will probably reveal it’s about half the size it used to be, which means your PC is not only going to run faster,
Finalising hardware settings
To find out exactly what Windows thinks you’ve got installed, right-click on the My Computer icon and choose Properties. This will bring up the System Properties dialog box. Switch to the Device Manager tab and have a look to see if all your hardware is listed.
If a device has a yellow triangle with an exclamation mark next to it then it’s got a problem. Highlight the device and click Properties to get more information about what’s wrong. It’s usually the case that reinstalling the software drivers from your backups will solve the problem. Occasionally, if Windows is being really stubborn, you might need to remove the device from your hardware profile altogether and reinstall it through the Add New Hardware Control Panel before it starts to work.
It’s all over
, you now have a fresh installation of Windows. Once you’ve set your system up you might like to consider creating a drive image. Next time you want to reinstall Windows you simply copy this back on to your C: drive – this gets the job done in half the time and without the worry of setting it all up again.
Reinstalling your hardware
Run Add New Hardware from the Control Panel and Windows searches for plug-and-play devices that aren’t properly installed, producing a list like this.
Aug 21, 2008 | Computers & Internet
Trying to start from scratch
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Feb 13, 2008 | Toshiba Satellite A105 Notebook
System not booting
take windows xp cd and repair from the cd
Sep 01, 2007 | Microsoft Windows XP Professional With...
Corel DRAW Graphics Suite 12 Logo
24 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
