Question about Cell Phones
When I try to reply to a text message I get SMS centre and I can't progress any further than that. HELP!
My phone is, all of a sudden unable to send a text. Every time i push the send option it says sms centre This is when i try to reply to a text or create and send a text. Why is it doing this ? how can i...
Usually this happens when the SMS settings of your phone were altered. First option on that is to call your service provider and ask for the SMS settings, including the message center number. Second option is to provide us the model number and your service provider for us to look that one up for you.
Apr 04, 2011 | Samsung Cell Phones
Nokia 1112 cannot send text messages but can receive
You cannot send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number. To get the correct message centre number please call your service provider and they will provide you the number.
Menu > Messaging >Options >Settings > Text message >Message centres
Thank You
Apr 04, 2011 | Nokia 1112 Cellular Phone
My phone can't write text messages (they are converted straight to MMS and when i convert it to text it still dosen't work), nobody can receive them, i can't reply to anything (it keeps expecting me to...
Problems sending or receiving SMS may be caused by no or incorrect SMS settings. To set up your phone to use SMS, you need a message centre number, which is provided by your network operator. This is often set up automatically when inserting a new SIM card to a phone. Whiteout the message centre number, you are not able to send or receive SMS.
To edit the service centre number:
  1. Select Menu > Settings > Connectivity >Message settings.
  2. Select Text message.
  3. Highlight Service centre and select Edit.
  4. Highlight a service centre number and selectOptions > Edit > Continue.
  5. Enter the service centre number and selectSave > Yes.
  6. Highlight the service centre number and selectSelect to use the defined service centre number.
To add a service centre number provided by your network operator:
  4. Select Add to add a new service centre number.
  5. Enter the service centre number and selectSave.
This should help you.
any further questions feel free to ask.
Thanks.
Nov 19, 2010 | Sony Lands Phones
SMS
hi..
In your Message settings ,there is an Option called as reply via same centre ,please put that to NO.Then check weather You can send the messages.
follow the steps to go to that option
Menu--->Messages---->messagse settings---->Text messages---->Reply via same centre.
thanx
Jul 20, 2010 | Nokia 5320 XpressMusic Cellular Phone
How do i reset the settings so that the default message is SMS
Changing your text message
settings
Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you
can do this using the Settings options.
Press Menu, select Messaging, then choose
Settings and Text message. You can make
changes to:
Message types - Convert your text into
Voice, Fax, Paging, X.400, Email or ERMES.
Validity period - Choose how long your
message is stored at the message centre.
Delivery report - Choose to receive confi rmation that your message was
delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details
for your message centre. Character encoding - Choose how your
characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to
send your message as SMS or MMS when you enter a text longer than 2 pages in the message field.
Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message
settings Your KC550 message settings are predefi
can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message.
You can make changes to:
Slide duration - Choose how long your
slides appear on screen. Priority - Choose the priority level of your
multimedia message. Validity period - Choose how long your
message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
FOR MORE SEE USER MANUAL
good luck
Mar 21, 2010 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
My text messages are not sent out until days later, I have the Request Delivery report option turned on and still no text being sent out. I receive text with no problem.
check out the sms centre number,turn of reply via same centre,make the validity as maximum and put the message type as text,switch off and restart your mobile.
Mar 20, 2010 | HTC HD2 Smartphone
Nokia 6120 is not sending sms it gives msg
Try going into message settings found in your messages. Then go into text messages and look for the command: "Reply via same centre" activate this to yes then try again.
Mar 25, 2009 | Nokia 6120 classic Cellular Phone
Error message when texting on Ericsson K750i mobile
tmuncey hello,
Sometimes because of a phone bug or a SIM error, the "Service Centre" for SMS messages is changed.
Please call your cellular Service Provider, and ask for their SMS Service Centre settings.
Then, go to Messages > Settings > Text Message > Service Centre.
Make sure the number you were given by the Service Provider matches the one written there.
If not, please changed to the one given to you by the Service Provider.
Oct 29, 2008 | Sony Ericsson K750i Cellular Phone
MMS messaging?
This may be the problem...
Go to messages,
press menu ( - )
go to message setup,
then MMS message setup,
then go on composing MMS,
change the reply type to short reply
Hope this helps
Mowcius
May 13, 2008 | Motorola Mobility RAZR V3
Sms messaging centre deleted
You can get the msg center number from your service provider.
Call them on the fault reporting number (should be free) and they'll give you the number.
Jan 17, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
63 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
