Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Linksys WRT54G wireless router problem using Vista
The router was working fine an all the sudden lost connection.Now we have to by pass the router to get on the internet what happened? I need the router working can you help me.
  • jonest Dec 16, 2007
    i'm wondereing if it is the modem as i still lose internet connection when wired direct to the modem, have spoken to ntl but they've said there's nothing wrong with the line.
  • 2,351 Answers
I have both, the Linksys's wireless-g router with speedboost and a linksysrouter 4 port router. At any given time either router can and does drop off. Continue with pasha19's actions, however I suggest before you start unplug the power to the routers. Using a pen press and hold the reset button at the rear of the routers for at least ten seconds. If using a DSL router do the same. Power all back up and continue with pasha19's instructions. Just doing the reset may give you back internet.
Posted on Dec 16, 2007
  • 556 Answers
The following is not a solution but a set of steps to determine an issue. Wire the router back up -- connect a computer to it using a wire -- can it access the internet? If so the WAN side router config is fine. The issue appears to be a wireless issue. Did the wireless card lose the proper configuration settings to access the router? Did the wireless adapter disconnect and need to be reconnected?
If nothing above was an issue we need to do some other testing -- I do not believe this is likely in this scenario where things were working -- but as we have not yet found out a cause.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and one wireless computer attaching to the linksys router I want you to do the following
Click Start then All ProgramsLinksys WRT54G wireless router problem using Vista - 1.gif then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
The back in the window enter the following command using the default gateway from the wired connection (your router address)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in mLinksys WRT54G wireless router problem using Vista - 1.gifmilliseconds.
What you are looking for in the above
Good entries base
Wired IP address 192.168.1.u
SubNet Mask ?.?.?.? assuming
Default Gateway
DNS addresses ?.?.?.? not
where at least one is not zero.
Then wireless entries should be
Wired IP address 192.168.1.u should be 192.168.1.u
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
  • david Dec 16, 2007
    You have a point that intermittent problems are hard to identify because they resist any reasonable attempts to isolate them. On your side of their their device you have only the connecting cable (ethernet?) and the computer itself and it's network adapter or your router.
    Are there any indications that a single machine is having the issue? -- I would guess not from what you have indicated.
    Would all machines die simultaneously when the router was connected? from what you have said that is possible and may have been the case recently.
    What could affect all machines silmultaneously with the router hooked up and the individual machine when the router is removed -- there is only a single possible common part -- not belonging to the ISP (who I am not sure is blameless yet there is little we can do about them). -- the ethernet cable from their equipment to either your router or your computer assumimg it was not changed when you disconnected the router.
    Simple test if there are two ethernet cables of comparable lengths in your network to the cable from the ISP's equipment to the router or single computer swap that cable with the one of comparable length. (The odds ov both cables being defective should be very low.) If the suspect cable was the problem it will probably affect the router to computer link that it moved to. The issues that take down the whole network should vanish as the first length of ethernet cable will not be having issues any longer if the theory is correct. After all thos plotting it may make no difference but at the very least we can say we tried something -- and are looking for a difference.
    Other than that you got a lesson in some basic network testing commands like ping and ipconfig and addressing for multiple networks under your control. All in all not a total loss.
    Good luck I'm not sure I have much more to offer without additional input but I will respond to additional comments by you.
My wireless has suddenly lost connection. My wired works perfectly.
If the wireless has stopped working, but wired can, either your wifi modem on your laptop needs to be reset or the wifi router has to be reset. Make sure you have restarted your laptop and unplugged the wifi router.
Feb 26, 2011 | Linksys Wireless-G WRT54G Router
Wireless-G WRT54G Router: I lost internet connection from router. Everythin...
Unplug both router and modem. Disconnect modem from router. Wait 5 mins and reconnect everything.
May 18, 2010 | Linksys Wireless-G WRT54G Router
Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
Dec 11, 2009 | Linksys WRT160N Wireless Router
Lost wireless router CD
You can make the router working even without using the CD. Who is your ISP? Are you having concern with wired or wireless connection?
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Linksys wrt54g with sony vaio webcam won't work
check the LAN cable from the internet connection going to router.make a sure that wire is OK.if the wire connection is a ok go to your PC/unit then make sure the Lancard/wire less lancard driver is complete or remove the Old lan/wieless lan drivers and install a new or update the drivers.good luck and have a nice day
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Yes, this will work fine on any operating system Like Vista , all of the new Linksys router now like this one is already made to work with Vista operating system....
Hope that helps........
Oct 05, 2008 | Linksys Wireless-G WRT54G Router
I need a pass pahase
you can check the the passphrase on the setup page of the your router. does you laptop connects to the router via an ethernet cable.
reply to this post so I can give the steps on how to check it.
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
88 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
